Thread: audi a6 3.0tdi Quattro la mans 2008
Results 1 to 10 of 14
  1. audi a6 3.0tdi Quattro la mans 2008
    Motherwell
    Car starts ok and runs ok but there is a problem, I cant get out of park until the car has heated up to running temp. Wont come out of park and dose not show PRNDS on the display it will show that there is a fault with the auto parking break release, but that clears when you get the car up to temp and start driving. it says that there is no communication with transmission but everything is clear when it has wormed up and I can reset the fault codes and they they stay clear. so has anyone able to give me a fix for this or point me in the right direction PLEASE
  2. Re: audi a6 3.0tdi Quattro la mans 2008
    46 Post(s)
    If you tell us the engine we might be able to help a bit more. The Le Mans came with more than one engine.
    I suggest getting the car scanned for faults but obviously you'd need someone who can come to you.
  3. Re: audi a6 3.0tdi Quattro la mans 2008
    Jan 2013
    Wessex. and Southern France
    108 Post(s)
    Multitronic box would be my guess.
  4. Re: audi a6 3.0tdi Quattro la mans 2008
    Motherwell
    Here is the scan when the fault is showing up but these all go away when the engine is at running temp.
    Tuesday,08,September,2015,11:40:10:30570
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.3.0 (x64)
    Data version: 20140905
    VIN: WAUZZZ4F78N140316 License Plate: S5 OBK
    Mileage: 225230km-139951mi Repair Order:
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 36 37 42 46 47 4F 52
    53 55 56 61 62 6C 6D 72 76 77
    VIN: WAUZZZ4F78N140316 Mileage: 225230km/139951miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Sporadic communication error 1000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    07-Control Head -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    1E-Media Player 2 -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: Cannot be reached 1100
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Xenon Range -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    61-Battery Regul. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: Malfunction 0010
    6D-Trunk Elect. -- Status: OK 0000
    76-Park Assist -- Status: Malfunction 1010
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 059-907-401-ASB.clb
    Part No SW: 4F9 910 401 HW: 4F0 907 401 C
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H05--- Serial number:
    Coding: 0011372
    Shop #: WSC 02335 785 00200
    VCID: E2CD5ACA3D385B0E6D9-80B7
    3 Faults Found:
    005670 - Powertrain Data Bus
    P1626 - 000 - Missing Message from TCU
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 5
    Reset counter: 255
    Mileage: 225234 km
    Time Indication: 0
    Date: 2007.05.16
    Time: 12:09:07
    Freeze Frame:
    RPM: 798 /min
    Torque: 70.2 Nm
    Speed: 0.0 km/h
    (no units): 11.0
    Voltage: 13.45 V
    Torque: 581.4 Nm
    P1626 - 002 - Missing Message from TCU
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 5
    Reset counter: 255
    Mileage: 225234 km
    Time Indication: 0
    Date: 2007.05.16
    Time: 12:09:07
    Freeze Frame:
    RPM: 798 /min
    Torque: 70.2 Nm
    Speed: 0.0 km/h
    (no units): 11.0
    Voltage: 13.45 V
    Torque: 581.4 Nm
    005715 - Please check DTC Memory of ABS Controller
    P1653 - 002 -
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 5
    Reset counter: 255
    Mileage: 225234 km
    Time Indication: 0
    Date: 2007.05.16
    Time: 12:09:07
    Freeze Frame:
    RPM: 798 /min
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.53 V
    Bin. Bits: 00101000
    Torque: 214.5 Nm
    Bin. Bits: 00000100
    Readiness: 1 2 0 0 0
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
    Component: ESP8 quattro H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020876
    Shop #: WSC 02325 785 00200
    VCID: 66C5C6DA5110A72E011-8033
    2 Faults Found:
    01315 - Transmission Control Module
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 1
    Fault Frequency: 41
    Reset counter: 150
    Mileage: 224862 km
    Time Indication: 0
    Date: 2015.09.02
    Time: 13:25:07
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4082
    Hex Value: 0x0013
    Hex Value: 0x448E
    Hex Value: 0x00FF
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    000 - -
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 6
    Reset counter: 150
    Mileage: 225234 km
    Time Indication: 0
    Date: 2007.05.16
    Time: 12:04:24
    Freeze Frame:
    Hex Value: 0x00C0
    Hex Value: 0x0282
    Hex Value: 0x0024
    Hex Value: 0x0191
    Hex Value: 0x00FF
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0240
    Revision: 07020801 Serial number: 10601901057888
    Coding: 0000147
    Shop #: WSC 00121 210 90973
    VCID: E3C35FCE2222520666F-80B6
    Subsystem 1 - Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H46 0080
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    1 Fault Found:
    00263 - Transmission
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Reset counter: 150
    Mileage: 224862 km
    Time Indication: 0
    Date: 2015.09.02
    Time: 13:25:07
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 732 T HW: 4E0 035 729 A
    Component: Interfacebox H43 5150
    Revision: 00000000 Serial number: 351DN087561164
    Coding: 0011002
    Shop #: WSC 00000 000 08192
    VCID: 34616C92574C05BE4F5-8061
    Subsystem 1 - Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H01 0060
    Subsystem 2 - Serial number: 00000001130065
    Subsystem 3 - Serial number: 0118.07.080000000100010410ÿ
    Subsystem 4 - Serial number: 010410ÿ
    5 Faults Found:
    01964 - Control Module for Seat & Steering Column Memory (J136)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 80
    Mileage: 214552 km
    Time Indication: 0
    Date: 2015.02.10
    Time: 11:46:35
    01319 - Control Module for Distance Control (J428)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 79
    Mileage: 214552 km
    Time Indication: 0
    Date: 2015.02.10
    Time: 10:12:30
    01325 - Control Module for Tire Pressure Monitoring (J502)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 80
    Mileage: 214552 km
    Time Indication: 0
    Date: 2015.02.10
    Time: 12:48:02
    01327 - Control Module for Parking Aid (J446)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 190
    Mileage: 221804 km
    Time Indication: 0
    Date: 2015.07.10
    Time: 13:37:51
    02244 - Button in Control Head is Stuck
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 183
    Mileage: 224918 km
    Time Indication: 0
    Date: 2015.09.03
    Time: 16:34:37
    Freeze Frame:
    Bin. Bits: 00000000
    Bin. Bits: 0000000
    Bin. Bits: 010
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 A HW: 4F2 820 043 Q
    Component: KLIMABETAETIGUNGH30 0020
    Revision: 00000052 Serial number: 00000000517132
    Coding: 0001302
    VCID: 1C31A432DFDCADFE675-8049
    No fault code found.
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H18 0250
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0013122
    Shop #: WSC 02256 785 00200
    VCID: 316F6586A85E3096243-8064
    Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
    Component: Wischer AudiC6 H06 0190
    Coding: 00064784
    Shop #: WSC 02256
    Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0100
    Coding: 00146221
    Shop #: WSC 02256
    Address 0E: Media Player 1 (R199) Labels: 4E0-035-785.lbl
    Part No SW: 4E0 035 785 F HW: 4E0 035 785
    Component: SG ext.Player H15 0850
    Revision: 00000000
    Coding: 010000
    Shop #: WSC 02399 823 56573
    VCID: 2B5377EE4A725A461EF-807E
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH30 0280
    Revision: 09H30000 Serial number: 0037LD0XMTLK
    Coding: 0013381
    VCID: 295F8DE6808E4856EC3-807C
    Subsystem 1 - Serial number: 6332CSME31704427W
    Subsystem 2 - Serial number: 6342CSME3B7356513
    Subsystem 3 - Serial number: 6352QSME5F323C49U
    Subsystem 4 - Serial number: 6362QSME5F2C0F13V
    Subsystem 5 - Serial number: 63734SME5B77031D5
    Subsystem 6 - Serial number: 63834SME516F247BA
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
    Component: J0527 0410
    Revision: 00H03000 Serial number: 90055080930224
    Coding: 0102142
    Shop #: WSC 02323 785 00200
    VCID: 275B8BDE969A7E26FA7-8072
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4F0 920 982 T
    Component: KOMBIINSTR. M73 H23 0240
    Revision: 00000000 Serial number: 72W52L748
    Coding: 0000458
    Shop #: WSC 14557 067 57207
    VCID: 23439FCEE2A29206A6F-8076
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
    Component: J533__Gateway H06 0060
    Revision: 00H06000 Serial number: 1100B084128395
    Coding: F5D1FE7770320600
    VCID: 2D5779F6B466547600B-8078
    3 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 60
    Mileage: 213887 km
    Time Indication: 0
    Date: 2015.01.26
    Time: 20:03:02
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Reset counter: 189
    Mileage: 223787 km
    Time Indication: 0
    Date: 2015.08.14
    Time: 13:35:30
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 224862 km
    Time Indication: 0
    Date: 2015.09.02
    Time: 13:25:06
    Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
    Component: MP3-Changer H46 0390
    Revision: 00046002 Serial number: AUZ5ZBH8376524
    Shop #: WSC 00000 000 00000
    VCID: 1A3DA22AD5E8D3CE759-804F
    1 Fault Found:
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 7
    Fault Frequency: 6
    Reset counter: 150
    Mileage: 224902 km
    Time Indication: 0
    Date: 2015.09.03
    Time: 15:16:57
    Freeze Frame:
    Bin. Bits: 01000000
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
    Component: MNS ECE H51 1060
    Revision: 00000000 Serial number: 364D6087779778
    Shop #: WSC 00641 210 61280
    VCID: 3B7347AE7A12CAC68EF-806E
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0210
    Revision: 00000000 Serial number: Da
    Coding: 0003706
    Shop #: WSC 02327 785 00200
    VCID: 2C5174F28F7C5D7E175-8079
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
    Component: Komfortgeraet H27 0220
    Revision: 02200027 Serial number: 01109102480000
    Coding: 3549947
    VCID: 326D6A8AAD580B8E5D9-8067
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    1 Fault Found:
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 3
    Fault Frequency: 14
    Reset counter: 190
    Mileage: 0 km
    Time Indication: 0
    Address 47: Sound System Labels: 4F0-910-223-BO.lbl
    Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
    Component: DSP-High C6 H10 0240
    Revision: PROD_01 Serial number: 00000000079334
    Coding: 0000113
    VCID: 254781D6EC966C36C8B-8070
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H12 0100
    Revision: Serial number: 00000000538921
    Coding: 0001113
    VCID: DEB56E3A09407FEE491-808B
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0210
    Revision: 00000000 Serial number: a
    Coding: 0003706
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
    Component: EPB CDEC0080 H04 0080
    Revision: --H04---
    Coding: 0000321
    Shop #: WSC 02145 785 00200
    VCID: 204990C2F3B4891EBBD-8075
    1 Fault Found:
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 4
    Fault Frequency: 32
    Reset counter: 150
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    Freeze Frame:
    Voltage: 10.25 V
    Count: 243
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4L0 910 357 HW: 4L0 907 357
    Component: AFS 1 H01 0040
    Revision: 00000001 Serial number:
    Coding: 0000016
    VCID: E9DF4DE6C00E0856AC3-80BC
    Subsystem 1 - Part No: 4F0 941 329 D
    Component: AFS-Modul links H01 0010
    Subsystem 2 - Part No: 4F0 941 329 D
    Component: AFS-Modul rechtsH01 0010
    1 Fault Found:
    01314 - Engine Control Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 148
    Mileage: 216345 km
    Time Indication: 0
    Date: 2015.03.23
    Time: 16:18:35
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
    Component: TUNER EU/US/RDW H42 0620
    Revision: 00000000 Serial number: 394DW087890035
    Coding: 0000001
    VCID: 2E557EFAB9602F6E391-807B
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 219397 km
    Time Indication: 0
    Date: 2015.05.09
    Time: 21:02:41
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
    Component: J0644 BEM H12 0760
    Revision: 00000000 Serial number: 00000000066028
    VCID: 24419CD2E7AC953EDF5-8071
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 2804090457
    Coding: 344630393135313035442056413032383034303930343537
    Shop #: WSC 00000 384 00290
    5 Faults Found:
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 221116 km
    Time Indication: 0
    Date: 2015.06.21
    Time: 13:17:41
    02272 - Quiescent Current Stage 1
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 16
    Reset counter: 255
    Mileage: 214084 km
    Time Indication: 0
    Date: 2015.02.01
    Time: 11:25:13
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 8
    Reset counter: 255
    Mileage: 214084 km
    Time Indication: 0
    Date: 2015.02.01
    Time: 11:28:36
    02277 - Quiescent Current Stage 6
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 221222 km
    Time Indication: 0
    Date: 2015.06.26
    Time: 11:33:50
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00110001
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 190
    Mileage: 225050 km
    Time Indication: 0
    Date: 2015.09.05
    Time: 05:21:30
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0210
    Coding: 0003114
    Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
    Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
    Component: J772__Rearview 0050
    Revision: --H12--- Serial number: 525PA8-J83304Z
    Coding: 1020205
    VCID: 1E35AE3AC9C0BFEE891-804B
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 29
    Reset counter: 190
    Mileage: 221804 km
    Time Indication: 0
    Date: 2015.07.10
    Time: 13:37:49
    Freeze Frame:
    Term 15 On
    Reverse OFF
    Count: 3
    00778 - Steering Angle Sensor (G85)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 150
    Mileage: 225234 km
    Time Indication: 0
    Date: 2007.05.16
    Time: 14:07:36
    Freeze Frame:
    Term 15 On
    Reverse OFF
    Count: 3
    Address 6D: Trunk Elect. Labels: Redir Fail!
    Part No SW: 4F9 910 591 HW: 4F9 827 851 F
    Component: ValeoHeckdeckel H25 0290
    Revision: --H25001 Serial number: E5030000B
    Shop #: WSC 98765 666 38354
    VCID: ECD134F2CFFC1D7ED75-80B9
    Subsystem 1 - Part No: 4F9 910 592
    Subsystem 2 - Serial number: E5030100B
    Subsystem 3 - Serial number: RD12.04.08--H25001001A0157ÿ
    Subsystem 4 - Serial number: 1A0157ÿ
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0210
    Coding: 0003114
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
    Component: Parkhilfe 8-Kan H12 0080
    Revision: 00H12000 Serial number: 06340810020150
    Coding: 0221116
    Shop #: WSC 131071 1023 2097151
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 41
    Reset counter: 150
    Mileage: 224862 km
    Time Indication: 0
    Date: 2015.09.02
    Time: 13:25:05
    Address 77: Telephone Labels: 4F1-910-336.lbl
    Part No SW: 4F1 910 336 C HW: 4F1 862 335
    Component: BTA H11 0960
    Revision: 00H11000 Serial number: 00000007571224
    Coding: 0050021
  5. Re: audi a6 3.0tdi Quattro la mans 2008
    Nov 2012
    Somerset UK
    I thought all quattro 3.0tdi auto's were tiptronic and not multitronic
    That's what it says in the title of this thread.
    As Chris says a scan is in order, if your battery is the original one you could try a full trickle charge as it could be low.
    Just seen your scan, can I ask if they remain when you clear them? Can you confirm how old your battery is or if you have recently changed it...if so with what, was it a like for like swap and if not was it coded?
  6. Re: audi a6 3.0tdi Quattro la mans 2008
    Jan 2013
    108 Post(s)
    Doh!! Boy, is my face red!
  7. Re: audi a6 3.0tdi Quattro la mans 2008
    Nov 2012
    Somerset UK
    To match your car?
  8. Re: audi a6 3.0tdi Quattro la mans 2008
    Jan 2013
    108 Post(s)
    More sort of Misano really.
  9. Re: audi a6 3.0tdi Quattro la mans 2008
    Motherwell
    sorry for the delay in getting back, I can clear all fault codes when the car has heated up and the fault has gone, i can drive all day stopping and starting with no problems changes gear up and down both with paddles and auto but next day when cold the fault returns and I have to wait on the car heating up again. I haven't changed the battery and I don't know how old it is but the thing is well charged and starts the car with no probs.
    thanks MarkTM for your interest, Whimppy read the problem first.
  10. Re: audi a6 3.0tdi Quattro la mans 2008
    May 2014
    Darlington
    78 Post(s)
    Can you try and connect to address "02-Auto Trans" as it not showing up on the auto-scan. Also looking at the fault codes it could be a bad connection to the gearbox ECU or the ECU on it's way out.
    1 1 0
  1. 2008 A6 Le mans 3.0tdi Autowith Koni FSD Help
    By jugghead in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-04-2015, 08:16 AM
  2. Rear disc size on 2008 Le Mans 3.0 quattro saloon
    By furfurfur in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-12-2013, 05:45 PM
  3. Wheels from an A6 2.0Tdi Le Mans to A5 2.0 Tdi Quattro
    By Andy Grob in forum Wheels and Tyres
    Last Post: 02-05-2013, 01:45 PM
  4. Replies: 10
    Last Post: 17-04-2013, 10:06 PM
  5. Just bought me an A6 3.0TDI Le Mans Saloon 2008
    By invisiblekid75 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-02-2013, 01:21 AM
