Thread: 2001 beetle smoking bad oil smelt of petrol could cat be gone?
Results 1 to 8 of 8
  1. 2001 beetle smoking bad oil smelt of petrol could cat be gone?
    Nov 2013
    A, A
    Hi I have a beetle 1.6 2001 March its smoking bad like a white grey colour engine light on code is for the front lamba sensor garage have Said cat needs changing oil smells of petrol so changed oils plugs a leads and filter. Car runs well. Other than smoke went thought mot in May fine
  2. Re: 2001 beetle smoking bad oil smelt of petrol could cat be gone?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Welcome to the forum. Doubtful if a cat change would help, if code is for front (pre-cat) lambda sensor and your oil smells of petrol. Garage should be checking fuel trims and function of lambda sensor. Sounds like engine is overfuelling giving petrol in oil smell and smoking, but could be lots of reasons why.
    A full scan and posting results would give folks here more info on the forum and if you post the engine code ( three letter code ) in the front of the handbook or boot sticker it lets folks know exactly what engine you have.
  3. Re: 2001 beetle smoking bad oil smelt of petrol could cat be gone?
    Nov 2013
    A, A
    hi thanks for the welcome and the help the engine code is AYD trans code is FCH my mate came over to day to have a look it was smoking bad so he took the oil filler cap of and after a few minutes it stopped smoking
    he seems to think that its the valve oil seals as he said you can smell the oil in the smoke. told me best to get rid any idea
  4. Re: 2001 beetle smoking bad oil smelt of petrol could cat be gone?
    Pembrokeshire
    22 Post(s)
    take car to a garage, get a codes read and a diagnosis from a qualified mechanic. i don't think your mate is on the right line on this one, sounds more like it could be a blocked or faulty breather.
  5. Re: 2001 beetle smoking bad oil smelt of petrol could cat be gone?
    Nov 2013
    A, A
    hi did a code read which was for the front lamb sensor. he's normally spot on he checked breathers all are clear gets worse when its warm
  6. Re: 2001 beetle smoking bad oil smelt of petrol could cat be gone?
    Pembrokeshire
    22 Post(s)
    sounds like piston rings might be worn out.
  7. Re: 2001 beetle smoking bad oil smelt of petrol could cat be gone?
    Nov 2013
    A, A
    Hi I done a video of the smoke doesn't smoke on tick over only when revved how can I put it on here
  8. Re: 2001 beetle smoking bad oil smelt of petrol could cat be gone?
    Oct 2005
    Have you tried changing your CMOS battery?
  1. Please Help 2003 1.6 Beetle smoking from exhaust
    By `Shack in forum Beetle 2000-
    Last Post: 30-12-2015, 05:31 PM
  2. Please Help Oil Pump Failure, bottom end damage, 2001 A4 2.0 petrol
    By wak1out in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-11-2011, 11:09 PM
  3. Question 2001 Mk4 1.6 Golf petrol with low oil pressure
    By kayakhic in forum Golf MK4 - 1999 - 2004
    Last Post: 23-10-2010, 11:37 AM
  4. Audi A4 2.0 Petrol 2001 Oil Pick up line?
    By gcltd in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-08-2010, 12:32 PM
  5. Polo 1.4 petrol Sport bad acceleration and oil consumption
    By stephenbrowning in forum Polo - Derby - Lupo - Fox
    Last Post: 27-06-2010, 07:00 PM
