Thread: EPB issue
Results 1 to 10 of 19
  1. EPB issue
    Jan 2015
    United Kingdom
    Hi guys,
    So had an epb error come up on the dash, after acquiring vcds I did the scan below:
    VCDS Version: Release 15.7.0 (x64) Running on Windows 8.1 x64
    Data version: 20150820
    www.Ross-Tech.com
    Tuesday,25,August,2015,11:36:47:50853
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ8E225844 Mileage: 126020km-78305miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 FN HW: 03L 907 309
    Component: R4 2,0L EDC G000SG 2643
    Revision: --H01--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 84224 297 673320
    VCID: 76E3B6B60101988E7F-8022
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 K HW: 3C0 614 109 K
    Component: J104 C4 440 V2 0005
    Revision: --020--- Serial number: 00000785474829
    Coding: 0001291
    Shop #: WSC 05311 000 00000
    VCID: 2643A6F69121A80E0F-8072
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 HN HW: 1K0 820 047 HN
    Component: Climatic PQ35 142 1111
    Revision: 00142031 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 77FDBBB2060BE18664-8022
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 01000008245774
    Coding: 00888F0700041A00470A00000F000000000859435C00010000 0000000000
    Shop #: WSC 05124 000 00000
    VCID: 71E985AA686FBFB6AA-8024
    Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 180308 022 0601
    Coding: 00046997
    Shop #: WSC 05124
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
    Component: J234__006 VW10 HI 1815
    Revision: 19013000 Serial number: 0039DP6VL0G
    Coding: 0012342
    VCID: 3B7567827AA305E640-806E
    Subsystem 1 - Serial number: 6333FTS661430718
    Subsystem 2 - Serial number: 6343FTS604940718
    Subsystem 3 - Serial number: 6353ETS647SUSVNP
    Subsystem 4 - Serial number: 6363ETS6AV5USVNP
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 AE HW: 3C0 953 549 AE
    Component: J0527 0020
    Revision: 00026000 Serial number: 3C9953507AT
    Coding: 0000112
    VCID: 6FED83D27E5BA946BC-803A
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 971 E HW: 3C0 920 971 E
    Component: KOMBIINSTRUMENT VD1 1216
    Revision: V0002000 Serial number: 00000000000000
    Coding: 0007405
    Shop #: WSC 42850 001 1048576
    VCID: 275DABF2962BB10634-8072
    Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
    Part No SW: 3C0 907 530 E HW: 3C0 907 951
    Component: J533__Gateway H10 0080
    Revision: H10 Serial number: 1200P0841205C3
    Coding: F9807F060002022003
    VCID: 2345BFE2E2135D2668-8076
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
    Component: IMMO 042 0383
    Revision: 00042000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 39797D8A709F37F652-806C
    Subsystem 1 - Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1132
    Revision: 32008001 Serial number: 00000003588323
    Coding: 0000693
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.134 H08 1901
    Shop #: WSC 02069 000 90108
    VCID: 366376B64181D88EBF-8062
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 042 0472
    Coding: 0191020051030E763004941570085FCE107C01
    Subsystem 1 - Part No: 1K0 951 605 D
    Component: LIN BACKUP HORN H08 9001
    Subsystem 2 - Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Subsystem 3 - Part No: 3C0 951 171 C
    Component: Innenraumueberw.004 0611
    3 Faults Found:
    01135 - Interior Monitoring Sensors
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 48
    Time Indication: 0
    00323 - Vehicle Inclination Sensor (G384)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 125020 km
    Time Indication: 0
    Date: 2015.06.13
    Time: 16:44:39
    01134 - Alarm Horn (H12)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 48
    Mileage: 125020 km
    Time Indication: 0
    Date: 2015.06.13
    Time: 16:44:39
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1132
    Revision: 32008001 Serial number: 00000042388326
    Coding: 0000692
    VCID: 3C77649E7FAD02DE49-8068
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
    Component: J540 EPB3 VW-09393 0009
    Revision: 008 Serial number: 00000000420868
    Coding: 0000057
    VCID: 2959ADCA803F877622-807C
    3 Faults Found:
    03200 - Switch for Electric Parking Brake (E538)
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 43
    Time Indication: 0
    Freeze Frame:
    Voltage: 11.70 V
    Count: 10
    Hex Value: 0x0171
    Hex Value: 0x0088
    Hex Value: 0x1010
    02845 - Function Display in Instrument Cluster (!)
    007 - Short to Ground - MIL ON
    Freeze Frame:
    Fault Status: 11100111
    Fault Priority: 2
    Fault Frequency: 32
    Reset counter: 44
    Mileage: 125848 km
    Time Indication: 0
    Date: 2015.08.19
    Time: 20:04:01
    Freeze Frame:
    Voltage: 10.50 V
    Count: 78
    Speed: 0.0 km/h
    Hex Value: 0x1271
    Hex Value: 0x0001
    Hex Value: 0x1010
    02442 - Function Lamp in Control Head
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 83
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.10 V
    Count: 81
    Speed: 0.0 km/h
    Hex Value: 0x0871
    Hex Value: 0x0008
    Hex Value: 0x1010
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 AD
    Component: Radio GR0 034 0033
    Revision: 0003404S Serial number: VWZ2Z2H7076732
    Coding: 0040400
    Shop #: WSC 05314 000 00000
    VCID: 68DFE8CE5BB57E7EFD-803C
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
    Component: J388 TUER-SG HL 0307
    Revision: 41004101 Serial number: 00000000326557
    Coding: 0000144
    VCID: 70EF80AE6365B6BEA5-8024
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
    Component: J389 TUER-SG HR 0307
    Revision: 41004101 Serial number: 00000000322858
    Coding: 0000144
    End-------------------------(Elapsed Time: 01:37)--------------------------
    So, I wasn't too worried about the alarm errors as that could have been me earlier in the year accidently setting alarm off and turning the interior sensors off.... anyway I have just refitted a new vw epb switch, rescanned and cleared the errors.
    Turned the ignition on and I am still getting the epb error light come up on the dash and the dis saying to consult handbook etc, so I did a rescan and every error barring this one had disappeared:
    Coding: 0000057
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 44
    Mileage: 126025 km
    Time Indication: 0
    Date: 2015.08.26
    Time: 17:54:53
    Freeze Frame:
    Voltage: 11.50 V
    Count: 78
    Speed: 0.0 km/h
    Hex Value: 0x1261
    Hex Value: 0x0001
    Hex Value: 0x1010
    So, I went to ross tech error code wiki and discovered this:
    02845 - Ross-Tech Wiki
    02845 - Function Display in Instrument Cluster (!): Short to Ground
    Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    • Red Brake light or Electro-Mechanical Parking Brake (EPB) light ON
    • Auto-Hold function in Electro-Mechanical Parking Brake (EPB) disabled
    Possible Causes
    • When found in the Electro-Mechanical Parking Brake (EPB) control module this may be caused to a software problem as noted below.
    Possible Solutions
    • When found in the [53] - Parking Brake control module on the VW Passat or VW Passat CC RoW (Rest of World) vehicles would refer to TPI 2021874
    I tried googling TPI 2021874 but it just sent me to a thread on this site about different error codes...but obviously all within the epb module
    So, wondering what my next move should be, has anyone any ideas?
  2. Re: EPB issue
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Might need a software update via VAS (VW dealer or independent with VAS diagnostic equipment). VAS is able to connect to the "Mothership" in Germany whereas VCDS cannot.
    RichardSEL has a lot of dealings with software updates. Mine was updated at the same time the injectors were replaced under recall.
    1 1 0
  3. Re: EPB issue
    Jan 2015
    United Kingdom
    Quote Originally Posted by DMitch16 View Post
    Yer im thinking after reading around its software...but, being pessimistic im expecting it to need a new ecu...will ring vw in morning and see if they can reflash....just a bit of a gamble as if it does need a new ecu, then the extra cost of the reflash will be a waste
  4. Re: EPB issue
    Sep 2008
    SE London
    The re-flash is one hour at an indie. My VW dealer wanted two. But with a CC you shouldn't need it as you've got 3C0 907 801 J. That would've been re-written from manufacture to avoid the "False DTCs" problem (in reality it provided more protection for the switching transistors in the EPB module that had originally been under-rated). But that's in reference to the earlier TPI 2015075 that covers my '06MY B6 Passat. (I can send you that if you PM me again your email address) I have the same module as you, but after the two stage flash on mine ended up at version "GX"
    For the TPI 2021874 VW do get very possessive nerdy about their TPIs, especially over here. The only way to be kept uptodate as a lowly member of the public is by subscribing to Erwin. But then you'd only get the NAR ones. There's many US ones for download cultivated by the moderator of VW Vortex forum nater. But his list only goes up to 2009. See:
    VWVortex.com - ****Official B6 TSB Thread - Every TSB .pdf is inside!**** (Links work)
    To see whether there's a recall outstanding for your car enter your VIN into:
    UK: (Safety recalls only) Check for Safety Recalls : Volkswagen UK
    NAR (Recalls & Service Lookup):
    VW Recalls | Service Campaigns | Volkswagen
    See whether this clears your outstanding EPB fault reporting:
    0. Turn parking brake off. EPB button unlit
    1. Select control module address [53 - Parking Brake]
    2. Select [Basic settings - 04] and use Group 006
    3. Listen carefully, and you should hear the EPB close. When it closes you'll see Basic Settings at the top of your screen say "ON"
    4. Click [Done], [Go Back] Then [Basic Settings - 04] and use Group 010. This performs a function test on the EPB which will cycle a number of times. When it's done Basic Settings at the top of your screen will show "ON"
    5. Click [Done], [Go Back], then [Fault Codes - 02] If each procedure's completed correctly you should see "No Fault Codes Found"
    6. Cycle the EPB a few times to ensure all's now working correctly
    Post what Module 53 now reads?
    Best I can do for now...
    1 1 0
  5. Re: EPB issue
    Jan 2015
    United Kingdom
    Hi Richard,
    I am fast becoming aware that you are the 'oracle' lol i bet there is not much you don't know about passats lol
    I came across erwin the other night and bookmarked it for if I ever attempted repairs, would be worth a few euros to read through and print off some info
    I also found your post about the flashing issue and the modules affected re B and G iirc...I took a little solace from knowing mine isn't one of those specifically affected, but still understand the ecu as being sensitive all the same to low voltages etc etc
    I did a recall check via vw site soon after buying the car and again just a few days ago...nothing came up so that is something I suppose lol
    Brilliant stuff, many thanks for the suggestion of cycling the functions etc, I will give that a go and report back...at this stage anything that may prevent a very costly repair is always welcome...thank you for the help and suggestions
    p.s, i have an estate not a cc...I dont think that will make any difference but just mentioned in case
  6. Re: EPB issue
    Jan 2015
    United Kingdom
    Hi Richard,
    Well, just done the above suggested steps in vcds and immediately hit an issue. Group 6 when inputted and hitting go comes up with error not available, so tried group 10 to do the function test and that worked perfectly, came out ran a scan, cleared the faults, reran the scan after cycling epb on and off via switch a few times and error remains
    I have taken a couple of vids to show the procedure and to record the sound of the epb motors cycling on and off...unsure if any use, but they both sound to be cycling on and off fine, yet group 6 non availability would presumably be commensurate with an issue?
    Also, unsure if the voltage readings during function test is correct, they were both at 0 (despite unfocused pic but you didn't miss anything) and only registered voltage right at the end...is that normal?
    https://youtu.be/7kBP8DMaqp4
    Just a vid to relay the sound of the motors cycling on and off via epb switch
    Epb motors cycling via epb switch - YouTube
    Error code remains unchanged:
    Coding: 0000057
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 44
    Mileage: 126025 km
    Time Indication: 0
    Date: 2015.08.26
    Time: 23:16:59
    Freeze Frame:
    Voltage: 12.10 V
    Count: 78
    Speed: 0.0 km/h
    Hex Value: 0x1461
    Hex Value: 0x0008
    Hex Value: 0x1010
  7. Re: EPB issue
    Jan 2015
    United Kingdom
    Quick update,
    managed to find a local-ish indy garage, they are going to do a scan with their gear for 25, they've quoted 450 for epb ecu supply n fit which I thought was quite good, but he didn't seem to think it would be that, more like the motor/calipers...anyway, let them have a look and they can sort it out...can't handle error codes and warning lights, need it sorting
    Fingers crossed, they get it sorted first time and its not a case of chase the fault
  8. Re: EPB issue
    Sep 2008
    SE London
    There's just so much good info, a lot of it spread across may sites on the interweb, that I collect the most useful and sub them into .docs.
    Started with headunits (coz I got sold with my '06MY at one year old a sad RCD500 without MP3 or Bluetooth. This on the so-called fully loaded SEL) And it kinda went from there. Still, beats amateur radio or stamp collecting. Must get out more...
    Not an oracle or sage. I'll leave that to those who are/have been mechanics and give of their experience in here for free
    I'd be surprised if your remaining fault is the EPB module itself. But, if there's been a EPB motor fault for some time, then it's not unknown for it to take down the controller eventually.
    As you've now got the full VCDS genuine and registered, try Ross-Tech's own forum? It's a fast track into Ross-Tech's own one-year from purchase free advice centre run from their own server:
    Ross-Tech Forums
    There's Ross-Tech's own sponsored public forum at:
    VAG-COM Diagnostic Forum
    Both will need your full Autoscan for authentication
    Or email:
    support@ross-tech.com
    I've given them this thread's URL in case they can answer here.
    If they don't know the answer to why you're getting nothing in Group 6 then noone will. If you've retracted and opened the EPB several times without lock-up then that does indicate there's no motor fault either. The low voltage you're registering (11.7, 12.1V) could indicate a wiring or plug fault. Have you actually had the wheels off to see whether there's a crack lengthwise along either of the EPB motors? I've given them this thread's URL in case they can answer here.
    If you can hang on to your £450 for a little longer, let's see if spending that can be avoided?
    1 1 0
  9. Re: EPB issue
    Jan 2015
    United Kingdom
    Hi Richard,
    That degree of organisation can only be praised, it is something I aspire to but doubtful I'd achieve...I think I will start trying myself though, will prove to be a very useful repository of information. LOL Stamp collecting and radio, perhaps you could combine getting out more by going hilltop dx'ing (or whatever the technical name is) lol
    The guy I spoke to at the garage sounded taken aback when I mentioned the ecu, he said much more likely to be the motor/caliper
    You know, I never even considered asking ross tech for help/further info, good shout, I will register on the forum and see if they can shed any light...and wow, thank you very much for your help and thought to share this thread, that is really very much appreciated, thank you very much Richard.
    Yer the fact the brakes engage and disengage every time (upto now fingers crossed and wood touched) is what was pushing me towards the ecu, but of course, as you say, there could be any number of issues along the braking system that perhaps would lead to the issues experienced
    I haven't had the wheels off yet, I will take them off over the weekend and see if I can spot any immediately apparent issues with the motors.
    Thanks for your help, you have been brilliant
  10. Re: EPB issue
    Jan 2015
    United Kingdom
    So just to update for anyone else with the same faults:
    Dropped car off at garage this morning, they've just rang to say it is the epb ecu that's gone...Might help others pin down the same fault going off the vagcom codes etc
  1. Another EPB Question
    By mikecb1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-05-2016, 04:46 PM
  2. Epb reset
    By andy.burges in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 22-01-2015, 10:52 PM
  3. Another EPB Question
    Last Post: 02-07-2012, 06:21 PM
  4. EPB tool
    By team914 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 21-10-2011, 09:54 AM
  5. Important Passat EPB
    By Gerry T in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-08-2010, 05:37 PM
