Thread: uneven power delivery
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: uneven power delivery
    Jul 2011
    Norway
    Take a run in third from low rews and all the way up and look at the boost with VCDS in graphs, check if actual follow requested, if you see anything suspect, start by checking the vacuum pipes and especially the T connectors besides the fuel filter
  2. Re: uneven power delivery
    Aug 2015
    cardiff
    I'm a little unsure about logging
    Just to confirm
    I just use 'vc scope' and monitor 'Maf specified' versus 'Maf actual'
    I'm not sure how to show boost, do I measure certain blocks?
    Should I put anything else on that graph?
  3. Re: uneven power delivery
    Jul 2011
    Norway
    Boost is in Measuring blocks 11 , just take a short run to check if the turbo performs. Another thing ,when you hook up VCDS anyway, when engine is still cold, check the temp values , in MB 7 I think, they should all 4 be showing pretty much the same values
  4. Re: uneven power delivery
    Aug 2015
    cardiff
    I did a run, 3rd gear and uphill, and put it into http://vcviewer.com/
    log data also here
    Tuesday 25 August 2015 20:37:01:60804 VCDS Version: Release 10.6.0
    8E0 907 401 M 2.5l/4VTEDC G000AG 0004
    Group A: '011
    Engine speed Spec. intake press. Actual intake press N75 duty cycle
    TIME 2900-4000 1900-2300 mbar 1900-2300 mbar
    Marker STAMP /min mbar mbar %
    0.01 1322 1785 1122 85.2
    0.3 1346 2009.4 1254.6 85.2
    0.64 1392 2019.6 1315.8 85.2
    0.99 1438 2019.6 1387.2 85.2
    1.34 1485 2029.8 1448.4 85.2
    1.69 1554 2040 1519.8 85.2
    2.05 1601 2060.4 1601.4 85.2
    2.41 1670 2070.6 1703.4 78.5
    2.77 1740 2080.8 1825.8 73.8
    3.13 1833 2091 1938 69.4
    3.48 1902 2111.4 2050.2 61.5
    3.85 1972 2111.4 2162.4 57.2
    4.21 2065 2111.4 2244 52.9
    4.56 2158 2111.4 2274.6 50.9
    4.92 2227 2111.4 2315.4 46.9
    5.29 2320 2121.6 2366.4 43
    5.61 2390 2131.8 2397 40.6
    5.92 2459 2142 2325.6 47.3
    6.23 2529 2142 2091 57.2
    6.57 2552 2152.2 1978.8 57.6
    6.92 2598 2152.2 1948.2 58.4
    7.29 2668 2162.4 1958.4 58.4
    7.68 2714 2162.4 1989 58
    8.03 2714 2162.4 2019.6 58.4
    8.4 2761 2172.6 2050.2 60
    8.75 2807 2172.6 2080.8 60.4
    9.11 2830 2182.8 2101.2 61.9
    9.47 2900 2182.8 2131.8 61.9
    9.83 2923 2182.8 2162.4 61.2
    10.14 2970 2193 2182.8 60.8
    10.51 3016 2193 2213.4 60
    10.87 3062 2193 2223.6 57.6
    11.23 3086 2203.2 2254.2 55.2
    11.6 3132 2203.2 2264.4 54.1
    11.95 3155 2203.2 2274.6 51.7
    12.34 3202 2203.2 2284.8 47.7
    12.73 3225 2203.2 2274.6 46.6
    13.08 3271 2213.4 2244 45.8
    13.45 3318 2213.4 2223.6 46.9
    13.8 3364 2213.4 2203.2 47.7
    14.16 3410 2213.4 2193 48.5
    14.56 3434 2223.6 2182.8 48.9
    14.92 3457 2223.6 2182.8 49.7
    15.28 3480 2223.6 2172.6 51.3
    15.64 3526 2223.6 2193 51.3
    16 3573 2223.6 2193 51.7
    16.39 3596 2223.6 2203.2 52.5
    16.78 3619 2223.6 2213.4 52.5
    17.15 3642 2223.6 2203.2 52.9
    17.52 3689 2223.6 2213.4 52.9
    17.88 3735 2223.6 2213.4 53.3
    18.24 3758 2223.6 2213.4 53.7
    18.64 3782 2223.6 2223.6 52.9
    19.01 3828 2223.6 2223.6 52.5
    19.38 3851 2223.6 2223.6 52.9
    19.74 3851 2029.8 2223.6 59.6
    20.09 3666 1662.6 1774.8 52.5
    20.45 3689 1560.6 1489.2 72.2
    20.83 3573 1540.2 1591.2 58.8
    21.22 3526 1530 1642.2 53.7
    21.6 3410 1509.6 1632 51.7
    21.97 3318 1489.2 1601.4 61.2
    22.33 3178 1458.6 1570.8 62.3
  5. Re: uneven power delivery
    Jul 2011
    Norway
    A bit of turbo lag from start, pretty normal, I guess a new N75 wouldn't make things worse. Away from that, if you have low power in the top end, the turbo is not to blaim, must be something else.
    Could be the CTS or something more exiting like missing valve rockers or partly clogged up cathalysts or clogged up pick up in the tank or something else
  1. Quattro power delivery
    By mark- in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-12-2010, 09:23 AM
  2. Please Help Poor Power Delivery..
    By Zeb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-01-2009, 05:16 PM
  3. Help!! torque/power delivery down
    By Hurdy in forum Golf MK5 - 2004 - 2009
    Last Post: 11-06-2008, 07:27 PM
  4. Power delivery 2.5 diesel v6
    By ronmcintosh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-09-2007, 01:35 PM
  5. 1.8t juddering power delivery
    By djglovehead in forum Audi A3 - Archive Topics
    Last Post: 14-04-2007, 01:35 PM
