Thread: 2006, 2.7D, quattro turbo fault, (electronic side of things) + white smoke injectors 2? plz help
  1. 2006, 2.7D, quattro turbo fault, (electronic side of things) + white smoke injectors 2? plz help
    Aug 2015
    nrfolk
    please help, this is my first thread so i apologise if its in the wrong place
    i have 2006, 2.7 quattro, its just kicked into limp mode, sat in a layby and having a general hissy fit.
    i have pulled 2 codes via vcds/ vag com
    Address 01: Engine Labels: Redir Fail!Control Module Part Number: 4F2 910 402 C HW: 4F0 907 401 B
    Component and/or Version: 2.7L V6TDI G000AG 0010
    Software Coding: 0011372
    Work Shop Code: WSC 02334 785 00200
    VCID:
    2 Faults Found:
    013128 - Control Circuit for Controller for Turbocharger 1 (J724)
    P3348 - 005 - Electrical Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100101
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 221214 km
    Time Indication: 0
    Date: 2015.08.15
    Time: 14:10:10
    Freeze Frame:
    RPM: 3486 /min
    Torque: 429.0 Nm
    Speed: 155.7 km/h
    Temperature: 86.4°C
    Duty Cycle: 35.9 %
    Voltage: 13.83 V
    Duty Cycle: 12.2 %
    000565 - Boost Pressure
    P0235 - 001 - Regulation Range not Reached - MIL ON
    Freeze Frame:
    Fault Status: 11110001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 221216 km
    Time Indication: 0
    Date: 2015.08.15
    Time: 14:11:07
    Freeze Frame:
    RPM: 4158 /min
    Torque: 280.8 Nm
    Speed: 104.2 km/h
    Absolute Pres.: 2101.2 mbar
    Absolute Pres.: 1244.4 mbar
    Mass Air / Rev.: 528.8 mg/str
    Temperature: 30.6°C
    can someone please tell me if i can get the electrical side of the turbo reconned / replaced or do i have to go out and buy a new unit?
    has anyone ever had these problems before? if so ild love to hear your fix.
    oh also its pumping out white, diesel smelling smoke when in traffic, im aware that injectors are a common fault would this cause my turbo problem or am i looking at two expensive problems here??
    thanks for your time.
  2. Re: 2006, 2.7D, quattro turbo fault, (electronic side of things) + white smoke injectors 2? plz help
    Sep 2011
    Lurking over a keyboard ...
    Hi, welcome to VWAF! .
    The turbo actuator motor (J724) can be replaced on it's own, VAG service manuals have a procedure. It can be calibrated by VCDS but a bit tricky but VAS with other tools can for sure do it easier/quicker, more info in this post Link:- Fitting recon turbo,need advice
    1 1 0
  3. Re: 2006, 2.7D, quattro turbo fault, (electronic side of things) + white smoke injectors 2? plz help
    Aug 2015
    nrfolk
    thank you for the post, this is an earlier model, mines a a c6/4f but im sure the same sorta programming applies,
    thanks for your time mate, appreciated,
  4. Re: 2006, 2.7D, quattro turbo fault, (electronic side of things) + white smoke injectors 2? plz help
    Sep 2011
    The V6 TDi is same engine used in A4, A5, A6, A8, Q7, Phaeton plus Touareg , .
    There is only say slight variation on intercooler and some other bits but base engine same, diagnosis / tools / procedures etc same.
    There was a slight change to it after 2009 IIRC but 2004 - 2008 are same.
    Trust me spent a lot of time reading VAG tech docs and other bits relating to the V6 TDi, I'm only an owner but had more than my fair share dealing with this engine .
    The 2.7 is practically a detuned 3.0 TDi .
  5. Re: 2006, 2.7D, quattro turbo fault, (electronic side of things) + white smoke injectors 2? plz help
    Aug 2015
    nrfolk
    Awesome info, cheers mate, again i appreciate it, thanks
  6. Re: 2006, 2.7D, quattro turbo fault, (electronic side of things) + white smoke injectors 2? plz help
    Sep 2011
    No worries, google ssp 350 , first hit should be a PDF which has some general info which can be handy for a V6 TDi owner to familiarise themselves with.
    Page 29 show turbo and J724 .
    There are also some other SSPs floating around on the web .
    1 1 0
  1. Replies: 17
    Last Post: 07-03-2014, 02:27 PM
  2. Replies: 18
    Last Post: 04-01-2013, 10:47 PM
  3. grey/white smoke, turbo?
    By billy c in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2010, 08:53 PM
  4. 2006 t5 1.9 tdi, white smoke on start up
    By chicargo in forum The Commercial Range
    Last Post: 08-08-2009, 11:42 PM
  5. 97 a4 1.8 turbo white smoke
    By spjmm0 in forum Audi A4 - Archive Topics
    Last Post: 31-07-2006, 02:57 AM
