Thread: MK5 Golf cutting out while driving
Results 1 to 10 of 14
  1. MK5 Golf cutting out while driving
    Sep 2010
    LEICS
    Hey,
    Hope everyone's cool. I'm wondering if anyone else has had this issue or can help me out with it. I've got a MK5 Golf - 1.9 TDI 2005. BKC engine. About 6 weeks ago the car had issues starting. The first time it had an issue was a long start with the battery and starter cranking but no start. It worked eventually and no issues after that.
    At this time I had it scanned and it came up with a glowplug 1 error. Didn't get a chance to change it but it doesn't seem like a glow plug issue. Eventually changed the glowplug.
    Then about 4 weeks ago while driving after about 5 - 15 minutes of driving the car just cuts out. The revs drop and engine cuts out straight away. The dash still shows the fuel temp etc. The radio and indicator lights still work in dash.
    When I try to restart the car after it doesn't start. Cranks fine but just keeps on cranking. After about 3 - 5 minutes the car starts again. Usually I press the accelerator which seems to help. Then the cars fine for the rest of the journey (motorways/ A-Roads/ In town) anything it's fine for that journey. Then the problem persists the next time I take it out.
    The issue then stopped for about 4 weeks and now its started up again. My mate had a spare Maf sensor so changed that over and also cleaned out the throttle body.
    The car seems to cut out at junctions and when i'm slowing down and clutching/braking to change down gears. The revs just drop.
    The cars had a full service 6 months ago and the fuel pump was also changed at this time by the garage as it was weak and dying so it's got a new fuel pump in there.
    The issue sounds electrical related to me as the car isn't jerking or coughing like its not got any fuel when it cuts out.
    Had the car scanned a while ago and it wasn't showing any related error codes.
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
    VIN:
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 CB HW: 028 101 190 0
    Component: R4 1,9L EDC G000SG 6176
    Revision: 12345678 Serial number: VWZ7Z0D0586955
    Coding: 0000071
    Shop #: WSC 01279 785 00200
    VCID: 65CB9E1CAC681709FD9-8030
    1 Fault Found:
    17055 - Cylinder 1 Glow Plug Circuit (Q10)
    P0671 - 000 - Electrical Fault
    Freeze Frame:
    RPM: 903 /min
    Torque: 56.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 13.98 V
    Bin. Bits: 00001100
    Temperature: 16.2�C
    Bin. Bits: 10110000
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0021121
    VCID: 3A711D60755648F160B-806F
    No fault code found.
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 GA HW: 1K0 820 047 GA
    Component: Climatic PQ35 141 0909
    Revision: 00141027 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 69D3922C40703369D91-803C
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
    Component: Bordnetz-SG 1.0 H30 0704
    Revision: 00030000 Serial number: 00000000997349
    Coding: E4898F0600041800001400001400000000
    Shop #: WSC 00152 210 91233
    VCID: 3F876C746E746DD9575-806A
    Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer VW350 012 0401
    Coding: 00065493
    Shop #: WSC 00152
    Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
    Component: RegenLichtSens 005 0605
    Coding: 00479269
    Shop #: WSC 00152
    4 Faults Found:
    01064 - Terminal 58d; Interior Dimming
    00526 - Brake Light Switch (F)
    008 - Implausible Signal - Intermittent
    02395 - Parking Light Front Right (M3)
    00987 - Lamp for Brake Light; Left (M9)
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 H HW: 1K0 909 605 H
    Component: 02 AIRBAG VW8 023 0700
    Revision: 06023000 Serial number: 00385D0KG1L1
    Coding: 0012338
    Shop #: WSC 01268 785 00200
    VCID: 31633A4CA8208BA9D11-8064
    Subsystem 1 - Serial number: 6332MSME04490D06
    Subsystem 2 - Serial number: 6342MSME0B3F0C06
    Subsystem 3 - Serial number: 6351HSME17061A04
    Subsystem 4 - Serial number: 6361HSME4B160F04
    1 Fault Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenks�ulenmodul 500 0030
    Coding: 0000042
    VCID: 30653F48A32A82A1DEF-8065
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 970 F
    Component: KOMBIINSTRUMENT VDD 1520
    Coding: 0001401
    Shop #: WSC 00682 210 105872
    VCID: 2D5B263CB418EF49F59-8078
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 E HW: 1K0 907 951
    Component: Gateway H09 0110
    Revision: 09 Serial number: 270010490800B0
    Coding: 3D0F0B40070003
    VCID: 2953D22C80F0F369191-807C
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO 1520
    Shop #: WSC 01316 111 52970
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1K0 959 701 E
    Component: Tuersteuergeraet 09 0148
    Coding: 0000052
    2 Faults Found:
    00096 - Drivers Door Central Locking (Safe) Motor (V161)
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.2 1301
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 BL
    Component: 01 KSG 0301
    Coding: 98D802487F2D8505481BC69010
    Shop #: WSC 00873 210 91881
    VCID: 7BFFD8643AECB1F93BD-802E
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H02 1301
    Subsystem 2 - Part No: 1K0 907 719
    Component: Neigungssensor 003 0003
    Subsystem 3 - Part No: 1K0 951 177
    Component: Innenraumueberw.004 0101
    1 Fault Found:
    01134 - Alarm Horn (H12)
    004 - No Signal/Communication
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1K0 959 702 E
    Component: Tuersteuergeraet 09 0154
    Coding: 0000052
    3 Faults Found:
    00944 - Heated Exterior Mirror; Passenger Side (Z5)
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 L
    Component: Radio BVX 010 0022
    Coding: 0040402
    VCID: 2F673C34BE149D59C75-807A
    1 Fault Found:
    00857 - CD Changer Unit (R41)
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    End-------------------------(Elapsed Time: 01:31)--------------------------
    Just wondering if anyone can help as it's really frustrating
    Thanks!
  2. Re: MK5 Golf cutting out while driving
    Jun 2015
    Nuneaton, warwickshir
    7 Post(s)
    Hi dajackel
    This sounds exactly like the problem I (and hundreds of others) have had but with imported Mitsubishi Pajeros (2.8TD).
    When the importing of these vehicles from Japan began in the early 2000s they soon started cutting out after about 5 minutes of driving when approaching a junction. It took a while to restart but then would run fine for the rest of the day. The problem was traced to a diaphragm in the fuel pump that would leak/split due to the lower quality of diesel in this country as opposed to Japan. The diaphragm itself cost 50p but to strip and rebuild the fuel pump cost me £425 back in 2004.
    The fact that you have had the fuel pump replaced is too much of a coincidence to me. Was is new or reconditioned? Who did the work, dealers or other?
    Does the scan include the fuel pump? If it can be scanned I would concentrate on that or maybe get a fuel pump specialist to take a look.
    Hope this helps.
    Paj
  3. Re: MK5 Golf cutting out while driving
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    A quick check is to look at the anti shudder / manifold throttle flap to see if thats stuck shut when it fails to start. I had similar symptomson 1.9 tdi touran. The throttle flap adjusts while driving to regulate egr quantity and shuts when ignition is turned off to let the engine coast smoothly to a stop instead of back kicking on last compression stroke, and mine was sticking shut occassionally, no fault code came up.
  4. Re: MK5 Golf cutting out while driving
    Pembrokeshire
    22 Post(s)
    usual fault is the main ecu power relay. dry joints develop and cause it to stop.
  5. Re: MK5 Golf cutting out while driving
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    You have quite a collection of electrical faults and either quite a few components are on their way out or as Zollaf states it could a fault with main ecu power relay and it's causing most if the faults listed (unfortunately the times and fault frequencies are not shown so we can't tell if several faults are happening at the same times). Also an opportunity to check your door looms as the original looms are too short to allow the proper flex needed when opening and closing the doors and wires frequently break at that point.
  6. Re: MK5 Golf cutting out while driving
    Sep 2010
    LEICS
    Quote Originally Posted by PajeroGolf View Post
    Hi dajackel
    Hope this helps.
    Paj
    Hi mate, Thanks for the reply Yeah you could be right, The fuel pump was changed at an independent garage and they said it was a new one. I'll take a look at it this weekend and see if theres any diagnostics that can be done on it. Will keep you updated mate.
    Rob69
    Hi mate, i previously cleaned the anti shudder/throttle body out and there was ALOT of gunk in there, I'm going to attempt to take it out of the car this weekend and give it a thorough clean. I thought at the time it was activing abit weird as when I was testing it, it stay open when I put the ignition on (1 turn of the key) and when I turned it off the butterfly would close and then immediately re-open? Should it stay closed once the keys been removed? Next time she cuts out I'll check the position of it. Thanks mate.
    zollaf
    Thanks for the reply mate. Do you know which relay this one is? and any ideas of a part number? I'll get this replaced to rule it out.
    DMitch16
    Hi mate, Thanks for the reply. Yeah there does seem to be quite a few electricial faults. I can confirm that these haven't happened at the same time. The faults have occured over a period of years. The door loom did break a few years back and I had them repaired at the time and it seems to be working fine at the moment but I'll double check them this weekend.
    Reading up on several forums it seems quite a few people have issues like this and some people have suggested it may be the Crank/Speed Sensor, Relays, Temp sensor. Any ideas on these?
    Thanks for the replies. I will keep this thread updated.
  7. Re: MK5 Golf cutting out while driving
    Jan 2012
    10 Post(s)
    87 Post(s)
    Maybe clear all the faults and then start and run the car if you can then post a new scan of what's left.
  8. Re: MK5 Golf cutting out while driving
    Sep 2014
    Kampala Uganda
    Hi, I suggest you replace that pump n make sure you put in the exact one n make sure you get the people that installed it to check it again.
    They could start with a pressure test after a long journey.
    Cheers mate
    VW Bora V5, AGZ, 99, 5speed Manual Tranny.
  9. Re: MK5 Golf cutting out while driving
    Sep 2010
    LEICS
    just an update. I had the crank sensor changed for a new one as a few people on the forums said it's the likely culprit, changed brake light switch too and the issue is still there.
    Checked the anti shudder/egr vale when it switched off and it seems to be in the open position when trying to start it but it does still have the starting issue once it cuts out.
    I noticed that previously when it switched off when I cranked the engine the rpm needle did move but again it took a while to start up. I had to keep pumping the accelerator pedal.
    I've noticed that the car cuts off when I'm driving at speed and i switch gears to neutral, the revs just drop. I was going downhill and thought I'd try it, was probably on about 3k rpm in 4th gear downhill, switched to neautral and the revs dropped and it cut off. The battery light came on, I put it back in 4th (while still going downhill) clutched out and started up again so it looks like it does bump start back straight away but it's only if I stop and try to start it normally it takes a while to start up again.
    Again sorry for troubling you all this is getting annoying now.
    Where should i start looking now? ruled out the crank sensor.
  10. Re: MK5 Golf cutting out while driving
    Sep 2014
    Kampala Uganda
    I think something is loose check all engine grounds...
  1. Cutting out whilst Driving, VAG-COM data HELP
    By Bilibong in forum Polo - Derby - Lupo - Fox
    Last Post: 06-05-2012, 03:18 PM
  2. Please Help A4 54 reg - Ignition cutting out while driving
    By em2010 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-09-2010, 03:53 PM
  3. polo 1996 keeps cutting off while driving???HELP!
    By bimma100 in forum Polo - Derby - Lupo - Fox
    Last Post: 04-08-2009, 10:01 PM
  4. Important Engine Cutting out while Driving!
    By Paulw0t in forum Golf MK4 - 1999 - 2004
    Last Post: 30-12-2008, 01:15 AM
  5. Golf 1.6 Mk4 - engine cutting out while driving...
    By hemang02 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-10-2007, 12:59 PM
