Thread: Facelift Reverse Camera Unit Location
  1. Facelift Reverse Camera Unit Location
    Jul 2013
    76 Post(s)
    Has anyone done a OEM Retrofit of the reverse camera?
    Where does the unit fit into? ETKA say either side ELSAWIN say's the right hand rear boot area by the tools.
    I have no studs there to fit the holder to, if anyone has this on their car can you post up a picture.
    Thanks.
    Dan
    2009/2010 2.0 TDIe SE
  2. Re: Facelift Reverse Camera Unit Location
    May 2014
    Darlington
    78 Post(s)
    It should fit under the tools near the park brake control module. However I would look to make a mount near the MMI equipment, as If you have TV then you don't need to run a new FBAS wire to the Control head or 5F module.
  3. Re: Facelift Reverse Camera Unit Location
    Jul 2013
    76 Post(s)
    Thanks B5NUT,
    I dont have the TV, i'll just run a FBAS to the MMI unit.
    I have the plastic bracket that the unit sits in but i cannot see where the thing fits in to.
    I may have to put in a couple of rivenut studs in place.
    You don't happen to have a picture of where you put yours.
    Dan
  4. Re: Facelift Reverse Camera Unit Location
    May 2014
    Darlington
    78 Post(s)
    Sorry I don't, I fitted one to an Avant a few years ago, but the car had TV so just fitted the module with the MMI equipment on the left side, so I only had to make up a small FBAS cable. I also ran the cables to the camera using the left hand side hinge.
  5. Re: Facelift Reverse Camera Unit Location
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    Sorry to dig up an old thread, i have now brought a 2010 facelift A6 Avant, and wanted to fit the reverse camera, what parts do you need for this? (I brought most of it for my 2006 2g Avant but i dont think its the same parts for the 3g)
    any help or parts list would be appriciated.
    I have a genuine camera and boot handle, and the 4g0 camera module.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  6. Re: Facelift Reverse Camera Unit Location
    Jul 2013
    76 Post(s)
    Reverse Camera 4L0 980 551 B or 4L0 980 551 D ( 24/01/2011 onwards).
    J 772 Control Unit 4F0 910 441 D
    Plug less the pins for the control unit 4E0 972 144
    Bracket for the control unit 4F0 907 279
    You will need to get the Fakra connectors and cable if your not going buy a harness from Kuftec.
    J772 Pinout
    J772 Unit T54b pin No Allocation Wire Colour
    39 Can 14 L Orange/Green
    40 Can 14 H Red/Green
    43 Battery + (30) Fuse SF 1(5a) Red
    44 Ground Brown
    47 camera 1 Green/Yellow
    48 camera 2 Green/Red
    fakra green MMI J794 blue T12ac connector Core to pin 11
    fakra green MMI J794 blue T12ac connector Screen to pin 5
    fakra grey Camera
    Your 4go control unit is most likey for a 4g MMI car
    here is good link on the calibration of the camera http://www.audizine.com/forum/showth...ra-Calibration
    I was lucky as my unit was off a A6 sallon and did not need calibrating.
    Dan
  1. Please Help Reverse Camera (RVC) Help
    By vaslam1986 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-08-2017, 09:48 PM
  2. Reversing Camera on a Facelift 3G A6
    By dan2485 in forum In Car Entertainment
    Last Post: 11-04-2015, 08:58 PM
  3. Reverse Camera MMI 2G
    By StuS4 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-02-2015, 09:09 PM
  4. Reverse camera issues
    By gtime in forum In Car Entertainment
    Last Post: 25-03-2014, 03:21 AM
  5. Reverse Camera
    By topgunmatt in forum Golf MK4 - 1999 - 2004
    Last Post: 18-08-2009, 10:12 PM
