Thread: Engine Mount Solenoid Valve
Results 1 to 10 of 10
  1. Engine Mount Solenoid Valve
    Jan 2014
    Leek, Staffordshire
    15 Post(s)
    Hi all
    Having fixed the Xenon headlight range fault and replaced both fuel senders on my 2007 A6 Le Mans, thanks to brilliant advice from this forum, I am now left with one fault:
    Address 01 : Engine
    1 fault found
    005491 - Left Engine Mount Solenoid Valve (N144)
    P1573 - 001 - Open Circuit
    It has a fault priority of 0.
    Could someone tell me how serious this might be. (I am about to travel extensively in France)
    How easy is it to fix? Expensive?
  2. Re: Engine Mount Solenoid Valve
    134 Post(s)
    2024 Post(s)
    That means a new engine mount which are around £200 genuine and there are a number of different ones depending on the cars spec. Some are available aftermarket such as for the A6 4F quattro with the automatic six speed which I can do from Febi for £101.51 plus £10 P&P and this is in stock for next day delivery.
  3. Re: Engine Mount Solenoid Valve
    Jan 2014
    Leek, Staffordshire
    15 Post(s)
    Thanks Crasher.
    But how difficult is it to fit?
  4. Re: Engine Mount Solenoid Valve
    134 Post(s)
    2024 Post(s)
    Quite easy, release the nuts, lift the engine, remove the old and fit the new and re-assemble.
  5. Re: Engine Mount Solenoid Valve
    Jan 2014
    Leek, Staffordshire
    15 Post(s)
    UPDATE
    I decided to take it to the local Audi dealer.
    Part A4F0 199 379 BL £199.45 including VAT.
    3 hours labour £270 including VAT.
    Total £470 ouch!! (I did get 10% off this, as I have a service plan with them)
    Apparently, the front sub frame needs to be dropped.
    Not sure that I have noticed any difference.
  6. Re: Engine Mount Solenoid Valve
    Nov 2012
    Somerset UK
    But the fault's cleared?
  7. Re: Engine Mount Solenoid Valve
    Jan 2014
    Leek, Staffordshire
    15 Post(s)
    Re-checked VCDS after 200 miles. Fault has cleared!
    Suspension and brakes feel tighter. Maybe there was some slack in the system.
  8. Re: Engine Mount Solenoid Valve
    Dec 2011
    Swindon
    9 Post(s)
    How do you scan this in vcds? I have looked but can't find anything. Please help?
  9. Re: Engine Mount Solenoid Valve
    Nov 2012
    Somerset UK
    Geoff, this one won't show in a scan unless there's a fault, I think it does this in the 'engine' category as to list things that are OK would take too long.
  10. Re: Engine Mount Solenoid Valve
    Jan 2014
    Leek, Staffordshire
    15 Post(s)
    Yes, MarkTM is correct.
    If there is a fault with an engine mounting, it shows up in the engine category, as I posted further up the thread. No fault, no report!
  1. Replies: 2
    Last Post: 23-05-2017, 09:26 PM
  2. Right engine mount solenoid fault
    By tezread in forum A8 - S8 - V8
    Last Post: 30-01-2015, 05:00 PM
  3. engine mount solenoid valve?
    By markoA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-12-2013, 05:10 PM
  4. Please Help Mount solenoid valve
    By AUDI44 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-12-2013, 09:03 PM
  5. engine mount solenoid nalve
    By coupe2 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-09-2008, 07:25 AM
