Thread: Help with VCDS audi fault code terminal 30 U140A 00 [032]
Results 1 to 10 of 12
  1. Help with VCDS audi fault code terminal 30 U140A 00 [032]
    Jan 2009
    Wonder if any one can help me with a fault code checked on the site but
    can not find any information.
    The car is an Audi A3 2.0 TDI on a 2011 in the year
    The customers fault is the management light is on but the vehicle drives
    and runs fine with no faults showing on the car.
    I can clear the code with my VCDS but it comes back on when i turn the
    ignition on with out starting the vehicle
    Fault code is 17262 - Terminal 30
    U140A 00 [032] - Open Circuit
    Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 AB HW: 03L 906 018 AG
    Component: R4 2,0L EDC H26 9041
    Revision: 41H26--- Serial number: AUX7Z0K9FNH08C
    Coding: 00190012040501080000
    Shop #: WSC 06314 000 00000
    ASAM Dataset: EV_ECM20TDI01103L906018AB 003008
    ROD: EV_ECM20TDI01103L906018AB.rod
    VCID: 6ADC48E48D77BF71D0B-803F
    1 Fault Found:
    8169 - Terminal 30
    U140A 00 [039] - Open Circuit
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 121932 km
    Date: 2000.00.00
    Time: 00:00:00
    Readiness: 0 0 0 0 1
  2. Re: Help with VCDS audi fault code terminal 30 U140A 00 [032]
    Aug 2011
    Meath
  3. Re: Help with VCDS audi fault code terminal 30 U140A 00 [032]
    Jan 2009
    Thanks for reply, removed all fuses and checked also battery and supply feeds off engine fuse box still no luck with it
  4. Re: Help with VCDS audi fault code terminal 30 U140A 00 [032]
    Ambler, PA, USA
    post the complete AutoScan please.
  5. Re: Help with VCDS audi fault code terminal 30 U140A 00 [032]
    Jan 2009
    thanks for your reply to me please find info below
    Audi A3 2011
    VIN: WAUZZZ8PXCA075495 License Plate: MK
    Mileage: 121930km-75763mi Repair Order:
    Chassis Type: 8P (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 61 62 72
    VIN: WAUZZZ8PXCA075495 Mileage: 121930km-75763miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    1 Fault Found:
    8169 - Terminal 30
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 121932 km
    Date: 2000.00.00
    Time: 00:00:00
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 13424012092900FFC80F02ED901E0092380800
    VCID: 7BF27DA0FAED36F93BD-802E
    No fault code found.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
    Component: KlimavollautomatH09 0180
    Revision: 000065 Serial number: 8P0820043BM
    Shop #: WSC 00000 000 00000
    VCID: 78F862AC0BDB1DE156F-802D
    Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
    Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
    Component: BCM PQ35 M 110 0653
    Revision: 00110 AF
    Coding: 4E000A2FA005F0C0207041E00100015C427A29AA006DC12AE4 008F800041
    VCID: 3F8AC9B0AE75EAD9575-806A
    Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H11 0050
    Coding: 00DD13
    Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSEN H04 0003
    Coding: 024C2D
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumuebe H04 0020
    Subsystem 4 - Part No: 1K8 951 605 B
    Component: LIN BACKUP HO H11 9005
    Subsystem 5 - Part No: 1K0 907 719 C
    Component: Neigungssenso 005 0003
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
    Component: Airbag AU1042 H09 0250
    Revision: -------- Serial number: 003JU004D7J9
    Coding: 30314238303830303037554A305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 52ACF00405E717B188B-8007
    Crash sensor for side airbag; driver side:
    Serial number: 3572DRB40000E0B9115R
    Crash sensor for side airbag; front passenger side:
    Serial number: 3582DRB40000E0B9116T
    Crash sensor for side airbag; rear; driver side:
    Serial number: 35128RB4000066042250
    Crash sensor for side airbag; rear; passenger side:
    Serial number: 35228RB40000660D819J
    Crash sensor for front airbag; driver side:
    Serial number: 35547RB4000066E11E1N
    Crash sensor for front airbag; front passenger side:
    Serial number: 35647RB4000066E1103C
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H37 0070
    Coding: 0002012
    VCID: 4684DC5431AFBB11143-8013
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0100
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 983 HW: 8P0 920 983
    Component: KOMBIINSTR. VDO H02 0150
    Revision: D0H02002 Serial number: 2249K002009189
    Coding: 0260428
    Shop #: WSC 00001 001 00001
    VCID: 77FA619006C512995F5-8022
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 J HW: 1K0 907 951
    Component: J533 Gateway H43 1620
    Revision: H43 Serial number: 041011F1003566
    Coding: 352103
    VCID: 377AA1908645D2999F5-8062
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H02002 Serial number: AUX7Z0K9FNH08C
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
    Part No SW: 8P0 959 801 P HW: 8P0 959 801 P
    Component: Tuer-SG H04 0101
    Coding: 0131764
    VCID: 4898D26C3BBBAD61E6F-801D
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 233 3201
    Revision: 00H20000
    Shop #: WSC 02069 000 90108
    VCID: 3460969C57333981BA7-8061
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
    Component: AB2 SUBWOOFERBOXH07 0180
    Revision: 00006 Serial number: 92158124397986
    VCID: 3664AC94414F2B91843-8063
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 8P0 959 802 P HW: 8P0 959 802 P
    Coding: 0131764
    VCID: 499ED76820B15469F91-801C
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 186 AB HW: 8P0 035 186 AB
    Component: R Concert2+ H05 0293
    Revision: 00H05000 Serial number: AUZ1Z3L2349606
    Coding: 0310111
    VCID: 72EC50846DA777B168B-8027
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H43 1620
    Coding: F30B185A
    VCID: 71EE5F88A8A14CA9911-8024
    Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
    Component: J367-BDM H07 0180
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
    Component: Tuer-SG H04 0050
    Coding: 0131216
    Shop #: WSC 06314 000 1012544
    VCID: 428CC0441D87873138B-8017
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
    Coding: 0131216
    VCID: 4382C540029D8E3933D-8016
    End-------------------------(Elapsed Time: 02:24)--------------------------
  6. Re: Help with VCDS audi fault code terminal 30 U140A 00 [032]
    Ambler, PA, USA
    If memory serves, and I have not consulted a Wiring Diagram for your A3, 30 is the switched +12V circuit. There is normally a relay that is pulled in once the ignition switch is turned to the on position to give power to other devices. If I had to hazzard a guess, this relay is the source of your intermittent fault.
    So what would I do? I would buy some time on the erWin.audi website and I would copy the wiring diagrams for my car. Then I would get out my multimeter and start checking the circuit. The ECU for the engine is seeing this intermittent problem but no other module is complaining. That tells me the problem lies between the relay and the ECU.
    Good luck in your search for this gremlin. It will not be an easy one. Wiggle wires and such as you go to try to force the issue.
    1 1 0
  7. Re: Help with VCDS audi fault code terminal 30 U140A 00 [032]
    Jan 2009
    Hi Bruce
    Many thanks for your reply, i will try a relay and let you know how things go with it
  8. Re: Help with VCDS audi fault code terminal 30 U140A 00 [032]
    Ambler, PA, USA
    Did I suggest replacing the relay? Did I not suggest troubleshooting? I never shot gun these kinds of things.
    Maybe your luck is better than mine. Solutions to my problems always require time! But then, most often those solutions last!
  9. Re: Help with VCDS audi fault code terminal 30 U140A 00 [032]
    Jan 2009
    I have a relay on order, cheapest way to start trouble shooting, not quite understanding the shot gun thing!! but thanks again
  10. Re: Help with VCDS audi fault code terminal 30 U140A 00 [032]
    Ambler, PA, USA
    a shot gun blasts a ring of lead at a target. It is not a pin point precision shot. When we speak of "shot gun" troubleshooting, it means no work is being done to find the root cause. Rather, parts are being thrown at the problem without knowing the likelihood of their success.
    Its your money and your time. Do with both as you choose. Just do not come back at me and say, "You told me it is likely the relay." While I suggested it as a possibility and while I lean in that direction, I am bothered by the fact that other modules that should be connected to terminal 30 are not complaining. So you see, I would need to investigate further.
    That takes time. That takes some skill. Buying a relatively cheap relay and throwing it in may give a quick fix. Then too, it may open up new issues.
    Hope that clears up my thinking and explains the idea of "shot gunning" solutions.
  1. Question vcds fault code
    By pleasancerow in forum VCDS - General Questions
    Last Post: 11-07-2014, 08:04 PM
  2. P151D 00 [032] fault code
    By s7gpt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-10-2013, 08:21 PM
  3. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  4. Error Code 01826-032 Steering Sensor...
    By randall977 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-01-2010, 11:40 AM
  5. Please Help fault code 18010 battery terminal b+
    By yas_b in forum Polo - Derby - Lupo - Fox
    Last Post: 08-10-2009, 08:01 PM
