Thread: rough start up blue smoke only in morning or after sitting a while.
  1. Unhappy rough start up blue smoke only in morning or after sitting a while.
    Jul 2015
    derry
    hi all, recently my car is difficult to start when the engines cold ie mornings.
    once warmed up its fine and starts no problem.
    heres a video
    TDI Audi a4 blue/Grey smoke start up? - YouTube
    many thanks!
  2. Re: rough start up blue smoke only in morning or after sitting a while.
    108 Post(s)
    1816 Post(s)
    That says glow plugs, a fault code read will tell you if they are faulty or if it is something else like the coolant temperature sender.
  3. Re: rough start up blue smoke only in morning or after sitting a while.
    Jul 2015
    derry
    Hi, thanks for the reply, would there not be a light on the dash if there was a fault? I have a obd2 scanner but no fault codes appear. Thanks.
  4. Re: rough start up blue smoke only in morning or after sitting a while.
    Pembrokeshire
    22 Post(s)
    the fault is probably not in obd, and only some faults put the light on . get it scanned with a proper computer like vcds.
  5. Re: rough start up blue smoke only in morning or after sitting a while.
    Jul 2015
    derry
    Quote Originally Posted by zollaf View Post
    ok thanks for the reply zollaf
  1. Momentary blue smoke and rough running at idle!!
    By JonesyA6 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-06-2015, 07:53 PM
  2. Question VW Passat 2008 2.0 tdi BKP blue smoke and morning start problems
    By morkus in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-12-2013, 12:59 AM
  3. Blue smoke on start up
    By Peter_HMR in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-10-2010, 04:48 PM
  4. Blue smoke only in the morning....
    By Moscow in forum Golf MK4 - 1999 - 2004
    Last Post: 28-03-2008, 12:14 AM
  5. Blue Smoke in the morning
    By Rhino in forum Passat - Archive Topics
    Last Post: 28-03-2007, 11:25 AM
