Thread: Front and rear wipers and washers stopped to work
  1. Front and rear wipers and washers stopped to work
    Oct 2012
    Bishops Stortford
    Hi gents,
    I got an a3 2007 1.6
    Rear and front wipers are not working either the washers. Rear wiper arm stopped in the middle of the screen. No noise if I pull or push the column stalk. Fuses are fine (41-rear wiper motor, 42 dual-washer pump). Front wipers are not moving either. I removed the rear wiper motor plug and tested for 12V. 3 legs out of 4 had live. I am not sure if that is any good.
    Have not found the fuse for the front wipers yet.
    Any idea what to check/test?
  2. Re: Front and rear wipers and washers stopped to work
    Oct 2012
    Bishops Stortford
    I got some updates.
    If I use VCDS: 09-Cent. conv. -> output test
    I can make the front and rear washers work. But not the wipers. Does the wiper has any relay? Can I test the stalk somehow?
  3. Re: Front and rear wipers and washers stopped to work
    Jan 2012
    Coding Something
    Have you fitted any new headlights at all?
  4. Re: Front and rear wipers and washers stopped to work
    Oct 2012
    Bishops Stortford
    No, I haven't
    But I have done plenty of other jobs: new exhaust flex pipe welded, all brakes around, fuel flap resistor replaced, thermostat housing replaced. These should not effect the wipers.
  5. Re: Front and rear wipers and washers stopped to work
    Jan 2012
    Coding Something
    Did they work before any of this work was done, stalk signals ok with vcds I assume?
  6. Re: Front and rear wipers and washers stopped to work
    Oct 2012
    Bishops Stortford
    In measuring data, group 24: steering column switch information has different values (1,2,3,4 depends on the stalk position) but no wiper movement at all. If I select the rear wiper on the stalk this value won't change from 0.
    In an other group, 09: Dual washer pump+/- are OFF, both boxes. No effect if I apply the washer function on the stalk. (I am not sure if this is the right group to test the stalk.)
    I will check what job has been done before.
  1. Front Wipers Stopped Working - Tips Needed
    By Auditron in forum Golf MK4 - 1999 - 2004
    Last Post: 14-12-2014, 09:19 PM
  2. Front wipers failed and won't work [1.9tdi][06]
    By zYx in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-01-2014, 12:55 AM
  3. Please Help Front wipers stopped working
    By A4sport1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-06-2011, 01:39 PM
  4. Wipers stopped after engine turned off, now wont work!
    By stig414 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-09-2010, 04:34 AM
  5. Replies: 3
    Last Post: 23-12-2009, 11:42 AM
