Thread: A4 2.0TFSI very rough ildle/Misfire on cold starts - please help
  1. A4 2.0TFSI very rough ildle/Misfire on cold starts - please help
    Mar 2009
    Accra Ghana
    Hello Guys,
    I Have been having troubles with my 2008 B7 2.0T. Noticed my car idles very rough when I start for the first time i.e cold start, the engine will vibrate very bad as if it is running only on 2 cylinders. the check engine light will start flashing for about 10 seconds before it stays solid. but after 2 minutes it will be back to normal and run fine until another cold start start. I scanned and had the following codes.
    1. coolant temperature sensor - Sporadic
    2. Rear heater core
    I have replaced the coolant temperature sensor at rear of engine. Replaced spark plugs with new ones. replaced all 4 coils with brand new. this has made no difference. the problem is still there.
    I unplugged the MAF before starting the car this morning. the engine idled fine without blinking check engine light. the vibration/misfire was gone. I waited for the engine to cool and i plugged back the MAF. the problem was back. took it off again and waited for the engine to cool. started it and there was no misfire or vibration.
    I drove the car for about 10 minutes and was ok but just a slight change in engine sound probably due to the ECU running on default values due to the unplugged MAF.
    I want to replace the MAF but I want to be sure before spending another cash without solving the problem. Am sure the MAF may be faulty since the rough idle vanished when I unplugged it.
    I need your advice before making the next move by replacing the MAF.
    Thanks,
    Gordon.
  2. Re: A4 2.0TFSI very rough ildle/Misfire on cold starts - please help
    Aug 2011
    Meath
    The MAF sensor must be genuine so have a look at yours first. Aftermarket ones tend to be rubbish and they don't always generate a fault code
  3. Re: A4 2.0TFSI very rough ildle/Misfire on cold starts - please help
    Mar 2009
    Accra Ghana
    Thanks for the reply. Will have a look at mine. how do tell if its genuine or an aftermarket one?
  4. Re: A4 2.0TFSI very rough ildle/Misfire on cold starts - please help
    Aug 2011
    Meath
    There should be an Audi logo and part number on a genuine one
  5. Re: A4 2.0TFSI very rough ildle/Misfire on cold starts - please help
    Mar 2009
    Accra Ghana
    It has the Audi logo with part number 0SD 906 461. its is made by hitachi.
  6. Re: A4 2.0TFSI very rough ildle/Misfire on cold starts - please help
    Jul 2014
    Have you got VCDS - might be worth scanning for error codes or doing some logs to see how the MAF responds?
  7. Re: A4 2.0TFSI very rough ildle/Misfire on cold starts - please help
    Mar 2009
    Accra Ghana
    Update
    Thanks for your help guys. I got a proper VCDS cable and pointed out to cylinder #1 injector. i replaced with a second hand unit a friend (mechanic) gave me. cleared codes and car has been working like a dream.
    thanks you all.
  1. Question No power on cold starts
    By JonFox82 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-01-2015, 11:28 PM
  2. Please Help Rough idling when warm (starts fine cold)
    By Dazmond in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-07-2014, 09:57 PM
  3. Misfire/rough running
    By Fourbears in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-11-2009, 10:12 PM
  4. Cold Starts
    By PDL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-11-2008, 09:28 PM
  5. Cold Morning Starts
    By Stevebt in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-09-2007, 11:43 PM
