Thread: Slip ring fault? Faulty airbag scrib?
  1. Slip ring fault? Faulty airbag scrib?
    Jul 2015
    Sheffield
    I had my Beetles indicator stalk replaced and when doing so the garage damaged what they called the airbag scrib. Any idea what this is? This made the airbag light remain on and the ESP light randomly came on. They couldn't fix the fault and I was advised to go to a VW dealership for a diagnostics test.
    I did this and the fault was diagnosed as being a failed slip ring. I had this replaced but within driving 2 miles the airbag light came back on and the ESP light still randomly comes on. The dealership are now saying that further faults may be causing the lights to come on including an accelerator fault for the ESP light and/or a wiring pin problem, an airbag unit problem or a wiring issue between slip ring and control unit.
    Any ideas? I did think the whole point of a diagnostics test was to actually find the fault.
  2. Re: Slip ring fault? Faulty airbag scrib?
    Aug 2011
    Meath
    When you leave a car into any garage for repairs any damage they cause it's down to them to rectify not you. I'd be leaving it back and looking for a loaner until its repaired
  1. Slip ring removal help
    By blake1312 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-05-2014, 10:53 AM
  2. How to recalinrate steering wheel slip ring. fault code 01826
    By Adman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-10-2012, 07:51 PM
  3. Airbag slip ring/steering angle sensor replacement
    By young dub in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-11-2009, 02:21 PM
  4. Airbag slip ring
    By mdoo98 in forum Bora - 1998 - 2005
    Last Post: 21-09-2009, 08:09 AM
  5. slip ring etc 2.0t
    By bez101 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-05-2009, 04:47 PM
