Thread: Golf 1.6 AKL Compression Results
Page 20 of 20 FirstFirst ... 10181920
Results 191 to 197 of 197
  1. Re: Golf 1.6 AKL Compression Results
    Jul 2015
    manchester
    More that the bores are glazed and this will encourage oil consumption.
    I deglazed them though before fitting rings, how can they be glazed already?
  2. Re: Golf 1.6 AKL Compression Results
    1840 Post(s)
    Which oil did you use?
  3. Re: Golf 1.6 AKL Compression Results
    Jul 2015
    manchester
    I used Millers CRO
  4. Re: Golf 1.6 AKL Compression Results
    1840 Post(s)
    For how long or are you still on it? Do you have a picture of the bores after you honed them, they should have had a satin finish with a 45 degree cross hatch using a 220 ish grit stone and looked like this
    This are good original bores
  5. Re: Golf 1.6 AKL Compression Results
    Jul 2015
    manchester
    Yes still running that oil not done any miles just been letting it idle and occasionally revving it. No blue smoke just like a white steam/smoke from exhaust that smells like fuel,o2 sensor? And posted the pics of the honed cylinder on this thread and was told they are good
  6. Re: Golf 1.6 AKL Compression Results
    Mar 2017
    South africa
    Crasher, you're God sent. Thanks for keeping this thread active with continuous positive and to the T advice.
    I'm about to embark on the same journey. Hoping it won't take 2 years🙈
  7. Re: Golf 1.6 AKL Compression Results
    1840 Post(s)
    Me, positive, that's a first....
  1. Question 2.0t compression test and results
    By Sloppy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-10-2012, 05:10 PM
  2. Question Compression Test Results
    By m50yre in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 07-01-2011, 05:51 PM
  3. Compression test results - new engine?
    By Rutland Gizz in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-12-2009, 10:04 PM
  4. Compression test results - skim head?
    By Rutland Gizz in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 15-12-2009, 12:24 PM
  5. revving golf 1.4 akl
    By michaeljsaxton in forum New Member Introductions
    Last Post: 19-08-2009, 11:28 PM
