Thread: another soggy passenger footwell
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: another soggy passenger footwell
    Jul 2007
    glasgow
    35 Post(s)
    Open the bonnet in the car, look below windscreen and remove plastic trim by taking off wiper blades.
    This is called the " scuttle" area.
    There is a drain hole right in the middle below battery, take battery out and prod with long screwdriver and you will feel the hole if there is water in there.
    It will be full of leaves and debris from the road.
    Try and gently use a hose to wash all the rubbish out of the scuttle and then replace the cover and wiper blades.
    Then run hose all over windscreen and then check for leaks and report back
  2. Re: another soggy passenger footwell
    Jul 2007
    glasgow
    35 Post(s)
    1999 Audi A6 Water Leak DIY Tutorial - YouTube
    This gives you an insight into what I am saying.
    Do it first and report back. You might not have to remove the wiper blades, I cannot remember !
    Part 1 - How to stop rain water from getting into salon on the floor in Audi A6 - YouTube another view of removing wiper blades
  3. Re: another soggy passenger footwell
    Mar 2010
    london uk
    yes i did all that before i posted on here, should say as much in the first post.
    ive just driven for about 45 minutes and ive put an evian bottle with the top cut open to catch the water, 400ml crystal clear water : /
  4. Re: another soggy passenger footwell
    May 2014
    Darlington
    78 Post(s)
    I fixed a similar problem on a C5, and the water was getting in from around the seal for the pollen filter, similar to the issue on this Passat Water Leak , Bolk head
  5. Re: another soggy passenger footwell
    Mar 2010
    london uk
    definitely something to do with the air as it doesnt leak when the air con is turned off, though saying that it does leak when the car is turned off and ive had the air con running. hopefully learn something when i can get it on a four post lift and unblock the drains from underneath.
  6. Re: another soggy passenger footwell
    Dec 2007
    8 Post(s)
    Sounds like its doing what it says on the tin except drain is going wrong direction as you already know.
    You could look under the bonnet / car after a drive with a/c on, and when dribble is evident inside have a look and see if there is any hint of any dribbles under car or possibly on steering gear etc. If not gently press the insulation material inwards in general location of drain. This may be enough to open mouth of drain which sometimes stick closed
  7. Re: another soggy passenger footwell
    #17
    Mar 2010
    london uk
    all sorted, evaporator drain it was. i left it with local mechanics who charged me an hour for going at it from under the carpet and pulling the drain out from that end. sorted for £48.
    1 1 0
  1. HELP! leak in passenger footwell and more
    By melton2018 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-02-2014, 07:27 PM
  2. Question Wet passenger footwell
    By simonrk57 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-11-2012, 06:45 PM
  3. water in passenger footwell
    By mikeosborne13 in forum Golf MK6 - 2009 - 2013
    Last Post: 06-05-2010, 01:00 AM
  4. Water in Passenger Footwell
    By Paulpro in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-03-2009, 11:52 PM
  5. Wet Passenger Footwell
    By Evoblade in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-02-2009, 11:35 AM
