Thread: b7 2.0 tdi bluemotion oil light
Results 1 to 10 of 13
  1. b7 2.0 tdi bluemotion oil light
    Jun 2015
    United Kingdom
    hi, can anyone tell me where the oil switch is located on the engine, when ignition turns on, the oil light does not illuminate.
    regards,
    Kevin
  2. Re: b7 2.0 tdi bluemotion oil light
    Jun 2015
    United Kingdom
    ok, discovered that the oil sender is on the sump.this displays the oil temp on the dash ok but still no sign of an oil light, can someone else with a 2.0 blue motion 140, confirm that whenthe ignition lights come on, an oil light/symbol appears on the dash and goes out when engine is started.
  3. Re: b7 2.0 tdi bluemotion oil light
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    On my 140 diesel sport only dash lights left on once they all go out and before starting are battery and parking brake in red and engine symbol in amber.
  4. Re: b7 2.0 tdi bluemotion oil light
    Jun 2015
    United Kingdom
    Thanks for that. When the ignition first comes on, does the oil light come on then. On mine the light doesnt light at all and was wondering if it was faulty . Only lights left on are the three you describe.
    Kevin.
  5. Re: b7 2.0 tdi bluemotion oil light
    Pembrokeshire
    22 Post(s)
    yes, oil light should come on with the ignition and go off once started, presuming there is good oil pressure. how long have you owned the car ?
  6. Re: b7 2.0 tdi bluemotion oil light
    Feb 2013
    Maidenhead Berks UK
    7 Post(s)
    Rather poor photo of dash but it's only there for less than a second.
  7. Re: b7 2.0 tdi bluemotion oil light
    Jun 2015
    United Kingdom
    thanks+for the photo. the oil light symbol isnt lit on your car dash either, the oil light symbol is just left off the red p symbol for the hand brake.
    kevin
  8. Re: b7 2.0 tdi bluemotion oil light
    Jun 2015
    United Kingdom
    yes,that would be normal, but as far as I can see, the passat doesnt have an oil switch to put the light oil, it has an oil sump sensor.
  9. Re: b7 2.0 tdi bluemotion oil light
    Pembrokeshire
    22 Post(s)
    thats the sensor to measure the oil level. look for a sensor on or around the oil filter housing.
  10. Re: b7 2.0 tdi bluemotion oil light
    Jun 2008
    Western Europe
    I realise this thread is over 2 years old, but I recently purchased a 2014 Passat 2.0tdi and the oil light does not come on with the ignition.
    Just wondering did you find the cause of the problem?
  1. help...2010 passat bluemotion glow plug light flashing amber...
    By st dave in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-03-2014, 11:57 AM
  2. 1.6 Bluemotion oil leak
    By Bernardchudley in forum Golf MK6 - 2009 - 2013
    Last Post: 24-11-2013, 01:11 PM
  3. Oil Min Light Error - Oil Level Sensor Fault (2006 2.0l TDi S-Line)
    By i_786_i in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2012, 11:24 AM
  4. a6 2.5 tdi oil sensor light
    By swebbym3 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-03-2010, 10:09 AM
  5. 140 TDI Bluemotion
    By johnloaderuk in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-10-2009, 10:11 PM
