Thread: Stripped threads on v6 TDI BAU (Drive belt mounting plate part)
  1. Stripped threads on v6 TDI BAU (Drive belt mounting plate part)
    Jun 2015
    York, UK
    Having a LOT of bad luck with my new (to me) Audi Allroad.
    Cut a long story short. The thread which holds the drive belt idler pulley to the aluminium engine plate / cover bit has stripped its threads.
    Should I replace the cover, or just drill and helicoil it?
    Ian
  2. Re: Stripped threads on v6 TDI BAU (Drive belt mounting plate part)
    Aug 2011
    Meath
    There was a thread on this site about that issue a few weeks ago. Crasher said the plate needs changing and it's pointless using a helicoil IMO
  3. Re: Stripped threads on v6 TDI BAU (Drive belt mounting plate part)
    Jun 2015
    York, UK
    I'm also after a new Idler pulley too.
    Wheres the best place to go for these parts? (Pulley and Plate).
    Should I buy new? Second hand? Scrap Yard? - Im worried that I may buy a used part, and the threads be ruined on that too, and end up back at square 1!
  4. Re: Stripped threads on v6 TDI BAU (Drive belt mounting plate part)
    Aug 2011
    Meath
    Give these guys a ring, I'd be wary of a used one as well VW Audi Seat Skoda Specialists | Parts Service Modifications
  5. Re: Stripped threads on v6 TDI BAU (Drive belt mounting plate part)
    Jun 2015
    York, UK
    Managed to find a new INA pulley cheap online, so thats ordered.
    Been thinking about the threads... may take it to a local engineering firm who welds aluminium. If I get him to fill the hole with weld, I can then drill it out and re tap to the correct size. Cant see why it wouldn't work?
  6. Re: Stripped threads on v6 TDI BAU (Drive belt mounting plate part)
    Aug 2011
    Meath
    Might work if the hole is in the right place
  7. Re: Stripped threads on v6 TDI BAU (Drive belt mounting plate part)
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Check bolt for correct size tap - might be fine thread.
    Skoda Octavia II SE 1.9PD TDI
  1. 2005 Polo GT aux belt stripped
    By chally3 in forum Polo - Derby - Lupo - Fox
    Last Post: 14-02-2015, 03:31 PM
  2. Tensioner Bar threads stripped
    By liamthecoder in forum Golf MK4 - 1999 - 2004
    Last Post: 23-12-2012, 11:50 PM
  3. 1.6 TDI Drive belt problems
    By garboy1 in forum Golf MK6 - 2009 - 2013
    Last Post: 07-02-2010, 07:51 PM
  4. Please Help Front caliper carrier problem - stripped threads
    By batteryman in forum Golf MK4 - 1999 - 2004
    Last Post: 16-09-2008, 02:09 PM
  5. Timing belt stripped,tensioner broke, Cam question, Please Help
    By tchrgrl in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-07-2007, 03:09 AM
