Thread: VNT Rod Movement
  1. VNT Rod Movement
    Jun 2009
    Telford UK
    Hi All
    After last nights embarrassing over take up hill and going into limp mode I have a question about the VNT control rod
    Now its out of limp mode and I have my vacuum back I thought I would take a look at the vnt rod movement to check vacuum is good
    Can any one tell me if when the engine is started the rod should pull upto the top ish (that's what it looks like anyway)
    Then when you raise the revs above 2500 rmp it should drop down slowly as it does ??
    Is that correct
    Code read as 17965 - Charge pressure / Checked all pipe work fine / ordered N75 Valve just in case / and who knows what the turbo like inside but its just had a double dose of millers in the tank
    Thanks in advance
  2. Re: VNT Rod Movement
    1836 Post(s)
    In the vast majority of cases, 17965 is a sticking VNT system, the rod is doing what it should by your description.
  3. Re: VNT Rod Movement
    Jun 2009
    Telford UK
    Hi Crasher
    Thanks for the reply
    The turbo has had a good thrashing today (4th to 3rd gear 4000 revs) with plenty of black smoke
    Also car has had a full service today as a treat so hope she will keep going as she always HAS done
    Might be a good ideas that I get up to 3000 rpm more often as its rare I ever go up that end.....
  1. Question Should i be able to move the VNT actuator rod?
    By charliebrown in forum Bora - 1998 - 2005
    Last Post: 20-03-2014, 11:24 AM
  2. Please Help 2004 Passat PD TDi AVF - VNT Lever Movement - Is this one broken?
    By TKPeters in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-09-2011, 03:58 PM
  3. Question Sticky vnt actuator rod
    By GRAHAM.C in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-10-2009, 08:14 PM
  4. Question vnt turbo actuator rod
    By olds_kool in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2009, 11:25 AM
  5. VNT turbo - actuator arm movement
    By Izalman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-05-2008, 10:30 PM
