Thread: Audi V8 Variable stage inlet vacuum concern....?
  1. Audi V8 Variable stage inlet vacuum concern....?
    May 2012
    suffolk
    I have a 2001 Audi S6 with the 4.2 40v V8 ANK engine with the internal flaps on the inlet, giving better torque throughout the rev range, like so
    Whilst replacing some vacuum pipes elsewhere and i found something that i don't think is quite right. I looked it up and this is how it should be. Blue is vacuum from the inlet to both solenoids, then one solenoid opens the line up for one flap arm in red and the other solenoid opens up for the other flap in green.
    Mine however is plumbed in so both flap plungers are run off one solenoid in red. Then the other solenoid opens a flap in the airbox to let 'hot air' into the airbox, in brown.
    this is where the brown feed goes
    Is this correct? As it is i haven't got a 3 stage inlet i only have a 2, surely? there are no extra plugs for a solenoid that i can see, and no spare solenoids? what should power this flap in the airbox? As i see it, it should be piped up as the top diagram and the airbox flap should come from elsewhere? or is this a different setup where it is only a 2 stage inlet?
    Any help greatly received
  2. Re: Audi V8 Variable stage inlet vacuum concern....?
    1840 Post(s)
    Isn't there a vacuum pipe map on the inside of the bonnet?
  3. Re: Audi V8 Variable stage inlet vacuum concern....?
    May 2012
    suffolk
    Just checked back on photo's and it doesnt look like it. The only sticker looks like airconditioning specs or something like that.
  4. Re: Audi V8 Variable stage inlet vacuum concern....?
    1840 Post(s)
    Intake air changeover valve -N335
    Vacuum diagram of solenoid valves -N156 and -N335
    1 - Solenoid valve for intake manifold with changeover function -N156. Actuation for both vacuum units at intake pipe
    2 - Intake air changeover valve -N335. Actuation for the flap in air filter
    a - T-piece for the vacuum supply of solenoid valve-N156
    b - Vacuum pressure supply from intake pipe
    c - Vacuum pressure hose to flap in air filter
    d - T-piece for the vacuum supply of solenoid valve-N156
    e - T-piece for the vacuum supply of solenoid valve -N335 and the vacuum reservoir
    f - Vacuum line to vacuum reservoir
  5. Re: Audi V8 Variable stage inlet vacuum concern....?
    May 2012
    suffolk
    Thanks for your reply, that is exactly how mine is plumbed in, even down to where the joiners are.
    Looks like the S6 ANK engine is a 2 stage inlet and not a 3 stage as previously informed, but at least i know its piped up correctly.
  1. Variable inlet manifold, when does it open
    By tommo2 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-02-2013, 01:05 AM
  2. Audi S7 Needed for Stage 1 Preliminary Dyno!
    By Evan@APR in forum A7 - S7
    Last Post: 21-01-2013, 05:10 PM
  3. inlet manifold vacuum leak
    By king.lion in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-08-2009, 09:30 PM
  4. Vast 35-metre audi ‘monument’ takes centre stage at goodwood
    By stuart in forum "How To" Guides - Vehicle Related
    Last Post: 03-07-2009, 07:53 PM
  5. Replies: 0
