Thread: VAG CAN PRO available - North Yorkshire/Teesside areas
  1. VAG CAN PRO available - North Yorkshire/Teesside areas
    Oct 2009
    Whitby, North Yorkshire
    As per title, now have VCP as well as VCDS.
    Based in Whitby, North Yorkshire -- if you need any help, drop me a PM. Always willing to help fellow members out.
    Mike
    PM me if you're in Whitby/Scarborough/North Yorkshire/Teesside areas. Genuine Ross Tech VCDS HEX+CAN lead (covers any VAG model)
    Also now with VAG CAN PRO (VCP)
  2. Re: VAG CAN PRO available - North Yorkshire/Teesside areas
    Jun 2015
    Aspatria
    .HI.I have just bought vag can pro, do you import the flash files for the engine ecm your self.mike
  3. Re: VAG CAN PRO available - North Yorkshire/Teesside areas
    Oct 2009
    Not done any flashing yet (not even with VCP LOL!)
    Not had a lot a chance of using VCP, except for activating twin rear fogs on a few Octavias and Yetis with BCMs. To be quite honest, the demand for VCP has not been any where near what I expected compared to VCDS
    Mike
  4. Re: VAG CAN PRO available - North Yorkshire/Teesside areas
    Jun 2015
    Aspatria
    HI .Flashed a Passat ecu in uds format today piece of cake.mike
  5. Re: VAG CAN PRO available - North Yorkshire/Teesside areas
    Oct 2015
    Aylesbury
    so - I am looking to get a software package, which is better for occasional coding, caliper wind back, service light reset, fault codes, checking and logging values of air mass meters and injector correction values etc?? I used Ediabas in teh bmw and it seemed ot do everything ( for about £60 lol)
  6. Re: VAG CAN PRO available - North Yorkshire/Teesside areas
    Jun 2015
    Aspatria
    Hi.If you are wanting just to pay similar money you will be looking at a vcds clone.regards mike
  7. Re: VAG CAN PRO available - North Yorkshire/Teesside areas
    Nov 2023
    Scarbados
    Still around Mike?
  1. VAG-COM diagnostics Teesside area?
    By skeltonsuperstu in forum VCDS - Help Requests
    Last Post: 09-04-2011, 10:29 PM
  2. hello newbie from north yorkshire
    By caddychris in forum New Member Introductions
    Last Post: 19-03-2011, 08:12 PM
  3. Hello from North Yorkshire
    By c4ddyman in forum New Member Introductions
    Last Post: 22-04-2009, 05:10 PM
  4. newbie in North Yorkshire
    By bonehead77 in forum New Member Introductions
    Last Post: 07-04-2009, 08:36 PM
  5. Vag-Com in Cleveland/Teesside
    By Irri_Tant in forum VCDS - General Questions
    Last Post: 25-07-2008, 11:19 AM
