Thread: A6 2.5 tdi akn c5 run out of fuel just under half tank?
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: A6 2.5 tdi akn c5 run out of fuel just under half tank?
    When you turn the ignition on can you hear the pump wining for 2 or 3 seconds. Listen carefully. If no wine then remove the cover plate under the seat and check the connections and for a 12 volt feed when the engine is cranking. Regards Peter
  2. Re: A6 2.5 tdi akn c5 run out of fuel just under half tank?
    Jun 2015
    ancaster
    Ok will try this weekend I suspect the in tank pump to be non functioning is there a relay ?
    it's a 2000 a6 2.5 Akn auto saloon model.
  3. Re: A6 2.5 tdi akn c5 run out of fuel just under half tank?
    Jun 2015
    ancaster
    Im scared to run it near half a tank now if it is in tank pump is there a how to? And can I just replace pump not the whole sender assembly?
  4. Re: A6 2.5 tdi akn c5 run out of fuel just under half tank?
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by uelno1 View Post
    Is it the small plug on the top that could be the problem with a sluggish performance??
    I think you should start your own thread in the correct section and stop hijacking this one.
    A4 2.5 tdi QS (mapped)
    1 1 0
  1. Audi A3 TDI Does not start when fuel less than half a tank
    By keenu in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-08-2013, 09:24 PM
  2. Please Help Petrol light on at half a tank??
    By ICKY123 in forum Chat - Anything with wheels
    Last Post: 11-06-2013, 12:30 PM
  3. A6 2.5 TDi AKN Injectors/fuel lines leak
    By MrAff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-04-2013, 05:10 PM
  4. Half tank fuel starvation
    By scottjones924 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-04-2013, 11:07 AM
  5. A6 TDi Quattro Runs out of Diesel at half a tank!
    By dean warren in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-05-2009, 09:46 AM
