Thread: Help me diagnose if any concerns in VCDS log
  1. Help me diagnose if any concerns in VCDS log
    Aug 2012
    London
    I have been tinkering with my dad's A6 2.5 since the fuel injection pump tensioner became lose (see thread). Big thanks to ametlib for his help!
    I put it back together and had to move the belt one tooth in order to get the timing back to the default TDC setting. Since I adjusted the FIP pulley / belt I still think that the engine is a tad noisy. I dont think that the cam belt slipped.
    The TDI graph didnt seem to want to plot the figures (video here)so I was advised to run some logs on VCDS. So below is a list of the various codes.
    Anyone able to cast their eyes over the values and see if any settings are of concern?
    Address 01: Engine (4B1 907 401 D)
    16:57:25 Group 000
    032
    054
    000
    021
    100
    213
    059
    120
    154
    069
    16:57:25 Group 001: Injected quantity
    742 /min Engine speed 740-840 rpm
    6.6 mg/str Injected quantity 3.0-8.0
    27.1°KW Qty adj valve act. time 15-25*Ck
    93.5°C Coolant temp 85-105*C
    16:57:25 Group 002: Idle speed (#3:See label file)
    0.0 % Throttle position 0%
    0 01 01 Switches see label file
    93.5°C Coolant temp 85-100*C
    16:58:14 Group 003: EGR (Exhaust Gases Recycling)
    266.9 mg/str MAF (specified) 180-270 mg/H
    266.9 mg/str MAF (actual) 160-290 mg/H
    48.5 % EGR duty cycle 40-75%
    16:58:14 Group 004: Start of injection - Full load-4000rpm-85*C
    742 /min Engine speed 3800-4200 rpm
    2.4 °ATDC Spec. start 10-14 *BTDC
    2.6 °ATDC Actual start 8-16 *BTDC
    100.2 % Cold start valve
    16:58:14 Group 005: Start Conditions (last Engine Start)
    742 /min Engine Speed (G28)
    14.4 mg/str Starting Quantity
    2.6 °ATDC Start of Injection (act.)
    93.5°C Coolant Temperature (G62)
    16:58:31 Group 006: Cruise Control System (CCS)
    0.0 km/h Vehicle Speed (actual)
    0 0 Cruise Control Pedal Monitoring
    00011 Cruise Control Switch/Pedal
    1.0 Cruise Control Status
    16:58:31 Group 007: Temperatures
    48.6°C Fuel Temperature (G81)
    99.0°C Oil Temperatur (G8)
    52.8°C Intake Air Temperature (G72)
    94.6°C Coolant Temperature (G62)
    16:58:31 Group 008: Injection Quantity Limitation I (Torque Limitation)
    0.0 mg/str Torque Request (Driver)
    28.9 mg/str Torque Limitation
    15.7 mg/str Smoke Limitation
    16:59:02 Group 009: Injection Quantity Limitation II (Torque Limitation)
    0.0 mg/str Engine Speed (G28)
    99.0 mg/str Torque Request (Cruise Control)
    0.0 mg/str Transmission Limitiation
    99.0 mg/str Torque Restriction
    16:59:02 Group 010: Charge Pressure Control
    243.4 mg/str Mass Air Flow (actual)
    999.6 mbar Atmospheric Pressure
    1030.2 mbar Boost Pressure (actual)
    0.0 % Accel. Pedal Pos. Sensor 1 (G79)
    16:59:02 Group 011: Boost pressure limitation -Full load -3rd gear - 3500rpm
    742 /min Engine speed 2900-4000
    795.6 mbar Spec. intake press. 1900-2300 mbar
    1050.6 mbar Actual intake press 1900-2300 mbar
    85.2 % N75 duty cycle
    16:59:20 Group 012: Glow Plugs
    11111111 Glow Status
    0.00 s Pre-Glow Period
    13.53 V Supply Voltage (Terminal 30)
    16:59:20 Group 013: Idle Stabilization (Injection Quantity Deviation I)
    -0.71 mg/str Injection Quantity Deviation Cyl. 3
    0.31 mg/str Injection Quantity Deviation Cyl. 1
    16:59:20 Group 014: Idle Stabilization (Injection Quantity Deviation II)
    0.39 mg/str Injection Quantity Deviation Cyl. 6
    -0.24 mg/str Injection Quantity Deviation Cyl. 4
    -0.24 mg/str Injection Quantity Deviation Cyl. 5
    17:01:37 Group 015: Fuel Consumption
    7.2 mg/str Injection Quantity (actual)
    1.10 l/h Fuel Consumption
    0.0 mg/str Injection Quantity (specified)
    17:01:37 Group 016: Auxiliary Heating
    46.8 % Generator Load
    1000001 Auxiliary Heating Shut-Off Conditions
    00 Heating Element Activation
    17:01:37 Group 017
    17:02:02 Group 018: Injection pump
    13.60 V Supply voltage injection pump
    13.53 V Supply voltage from ECM
    00000000 Pump infos See label file
    0000 Eng. speed sensor see label file
    17:02:02 Group 019: Start IQ (in memory) - In case engine does not start
    330 /min Engine speed
    0.7 °BTDC Actual start of inj 2*B-4.7*A TDC
    20.8°KW Qty adj valve act. time
    49.5°C Fuel temp
  2. Re: Help me diagnose if any concerns in VCDS log
    Aug 2012
    London
    anyone see anything obvious?
  3. Re: Help me diagnose if any concerns in VCDS log
    1841 Post(s)
    The COI looks bang on.
  4. Re: Help me diagnose if any concerns in VCDS log
    Jul 2011
    Norway
    As above + the most interesting thing to read from this is in group 7 . We are freezing our arses off here in Norway and your IAT sensor reads 52 C !!!!!! Even if your very hot engine radiates a lot of heat to the inlet pipes ,especially at idle,
    you must have far,far better weather than we do !!!!
  5. Re: Help me diagnose if any concerns in VCDS log
    Aug 2012
    London
    Thanks Crasher,
    I took it to a specialist today that a friend of mine recommended. It was sounding awful. I suspect something mechanical isn't quite right.
    Might be time to look for a replacement!
    Ametlib,
    We don't often have great weather, don't be to jealous
  6. Re: Help me diagnose if any concerns in VCDS log
    1841 Post(s)
    Cam and follower wear.
    1 1 0
  7. Re: Help me diagnose if any concerns in VCDS log
    Aug 2011
    Meath
    Quote Originally Posted by Rudidudi View Post
    Thanks Crasher,
    Ametlib,
    We get the BBC here mate, temperature is always about 10 degrees hotter in the south of England than here!
  1. Replies: 1
    Last Post: 14-11-2013, 09:25 PM
  2. Can VCDS diagnose a power drain
    By turpal in forum VCDS - General Questions
    Last Post: 08-09-2013, 07:41 PM
  3. VCDS log
    By p1lts in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-07-2010, 08:56 AM
  4. VCDS (Vagcom)will not log in
    By basser in forum TT - 8N Forum - 1998 - 2006
    Last Post: 29-11-2009, 05:55 PM
  5. Vcds will not log in
    By basser in forum VCDS - General Questions
    Last Post: 29-11-2009, 02:47 PM
