Thread: OBDMATE OM580 OBDII EOBD Code Read Scanner
  1. OBDMATE OM580 OBDII EOBD Code Read Scanner
    Dec 2014
    sweden
    _http://www.uobd2.net/wholesale/obdmate-om580-obdii-eobd-code-read-scanner.html#Specifications
    Has any member tried this scanner and if so any comments
  2. Re: OBDMATE OM580 OBDII EOBD Code Read Scanner
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    It's ok for basic scanning, fault code reading / erasing etc. and used by my father on my sister's Mercedes Benz CLK (which throws up a code once every few years!) It's not the same as VCDS (VagCom) which is the closest you will get to the VAS dealership scanning system. It won't identify the module codes that make diagnosis and part replacement easier either. Some higher end ODB scanners can perform the necessary software tasks for example when changing rear brakes that have an Electronic Parking Brake motor but generally most are restricted in what they can do unless you go for a really expensive one. VCDS however is far, far superior in its functionality and is the preferred tool for the job although the "Enthusiast" versions start at $249 for genuine cables (software is free and downloadable). Bought my VCDS cable in the UK from Gendan for a shade under £200 when on offer.
  1. Please Help OBDII fault code P0322 & P0688 Showing on 2001 - S6 Quattro
    By bigwul83 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-09-2014, 07:33 PM
  2. OBD-II/EOBD Code Reader for VW GOLF Mk 6 2009 2.0L TDi
    By warrtydog in forum Golf MK6 - 2009 - 2013
    Last Post: 16-03-2014, 04:18 AM
  3. Please Help 1998 - 1.8 eml code - some advice please 17916 or eobd P1508
    By andybaz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-08-2012, 07:48 PM
  4. fault code scanner
    By andrew-spike in forum Site Sponsors - Request A Deal
    Last Post: 09-09-2010, 06:48 PM
  5. Sealy VAG Code Reader & Reset Tool - EOBD & Generic
    By cpiddy7 in forum Chat - Anything with wheels
    Last Post: 14-07-2008, 04:59 AM
