Thread: Passat B6 Non starting
  1. Thumbs up Passat B6 Non starting
    Jun 2015
    Bangor North Wales
    Hi, Ive got a B6 2ltr tdi 55plate, Its been an excellent car, but the other day when I got home
    I saw smoke coming from under the bonnet on the passenger side, I switched off the car, but
    when I came to start it again it cranked over 3 times then nothing, now the car went even try
    to crank. Anybody have any ideas? Ive had a quick visual look, ive removed the fuse box, it
    looks ok.
    Any help is appreciated
  2. Re: Passat B6 Non starting
    Sep 2008
    SE London
    So what state was the car when you saw the smoke? Did you have key in IGN? Was key in IGN position dash lights on only, or was it being started, turning over? Or had it already started and was in idle? How many miles? What was the last work done to it?
    What state is the car now? Lights on dash but nothing else? Do you have a test meter?
  3. Re: Passat B6 Non starting
    Jun 2015
    Bangor North Wales
    Hi, id just done a 20 mile drive, parked up, noticed the smoke from the passenger side under bonnet area, switched off the ignition,
    put the ignition back on and attempted to crank, but its cranked 3 times slowly. Im thinking bad earth, relay? All the lights come on the
    dash as should, but when I press the key in to start again nothing happens. As if the starter isnt getting a signal.
    Yes I have a multimeter, I was just wondering if there was anything common before I start digging into the cause.
    Its done 150k miles.
  4. Re: Passat B6 Non starting
    Sep 2008
    SE London
    Am thinking starter motor or solenoid -- either stuck perhaps. Place your multi-meter across battery and soas you can see it when you attempt to start. If there's no start now listen for any clicks as key is pushed in? What is voltage reading on meter at IGN on only. And as you try to start?
    Otherwise get yourself a VCDS Autoscan and post results here?
    There's nothing common or usual for what you describe. Any work done recently?
  1. Passat 2.0 BKD not starting
    By diag1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-07-2015, 01:17 AM
  2. Please Help Passat Strange Starting
    By Salrair in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-03-2014, 12:36 PM
  3. Passat not starting
    By Berkshire_Boy76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-08-2010, 07:58 AM
  4. Please Help Starting problem 06 Passat
    By squashabe in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-04-2010, 10:56 PM
  5. passat not starting
    By Brainscram in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2007, 11:42 AM
