Thread: engine fault
  1. engine fault
    Feb 2015
    Cambridge
    The wife came home last night and said the car was playing up. This morning it started ok but struggled to idle and was hunting badly for the first 20-30 seconds. The fan at the front was on full chat as well- something I have never noticed before. There was also smoke/ steam coming from exhaust and a smell of burning oil.
    After 30 seconds it settled and ran ok.
    Any ideas? I'm pretty good with me mechanics but its always good to get initial ideas from members on here. Thanks.
  2. Re: engine fault
    Pembrokeshire
    22 Post(s)
    any idea what car it is, or even better what engine ??
  3. Re: engine fault
    Feb 2015
    Cambridge
    Oh yes sorry.. 3.0 v6 2003 a4 cab.
  4. Re: engine fault
    Feb 2015
    Cambridge
    I put my generic code reader on it and I got p0116 engine coolant circuit (or something like that). Could it be that the signal is telling the engine it is warm when it I actually cold- hence fan coming on at full chat at start up? That's my theory.. I actually bought a coolant sensor a while ago as I read somewhere that it is a common fail. Comments please.
  5. Re: engine fault
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Coolant temperature sensor will do exactly that, tell the ecu to enrich or weaken the mix etc, so your on the right track in my opinion
    0 2 0
  6. Re: engine fault
    Feb 2015
    Cambridge
    Fixed. New sensor on this morn. Bit difficult to get to but not too bad.
  7. Re: engine fault
    Oct 2009
    10 Post(s)
    Top man,I hope you used genuine and not a cheap alternative
  1. Double Fault " Engine Fault - workshop & ESP Fault"
    By yusuf112 in forum Golf MK6 - 2009 - 2013
    Last Post: 10-02-2015, 10:23 AM
  2. Please Help engine management system fault& esp fault warning lamps coming on at same time.
    By passahat in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2014, 09:22 PM
  3. Replies: 3
    Last Post: 19-02-2013, 02:10 PM
  4. Engine fault and Emissions fault need some advice..
    By Crackman 619 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-10-2010, 10:15 AM
  5. Please Help Engine Oil Pressure light, No engine fault codes on VAG COM
    By dfilogik in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-06-2010, 08:28 PM
