Thread: RNS-E Vagcom won't communicate with radio or navigation module
Results 1 to 10 of 14
  1. RNS-E Vagcom won't communicate with radio or navigation module
    Apr 2014
    A, A
    Car:Audi A4 B7-2008-Owned since 2014
    Met up with a mate today to code an rns e stereo to accept aux
    Got vagcom plugged in; but i can't communicate with the Navigation or Radio Module it says "No Response From Controller",the RNS-E has been fitted since i've had it so i don't know if its been retrofitted. I've had the stereo out to see if it was a loose wire and it all seems intact. The wiring seems genuine so doesn't look like its an adaptor plugged in; now i'm clutching at straws here i spent absolute ages on it today. I've managed to find on a forum about someone fitting the RNS-E when they have the symphony stereo fitted and they moved 2 wires to allow vagcom to talk with it. but i wouldnt have thought this would be an issue as the navigation appears on the speedometer display thingy
    Ruled out vagcom working as i can access other modules as i turned off seatbelt chime, disabled auto locking at 15mph
    Also the navigation displays on the speedometer thingy so the stereo does seem to talk with the car just not vagcom
    Any help would be appreciated!
  2. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Dec 2013
    Derby
    I'm in the same boat as you fella & have struggled to find an answer thus far so hopefully someone will be able to help out with this.
  3. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Feb 2014
    West Sussex
    Is there a chance the unit came from another car and was coded to canbus and not k-line?
    Not sure if this could be the case as I think this would prevent it working full stop
    Audi TT Roadster S-Line Quattro in Daytona Grey
    New, shiny and still topless
  4. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Dec 2013
    Derby
    It was something along those lines that I read myself but buggered if i know what wires to swap over, did'nt want to do any damage.
  5. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Apr 2014
    A, A
    If you message me i've managed to get mine sorted and coded for the aux
    Quote Originally Posted by Audi A4 S line View Post
  6. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Feb 2014
    West Sussex
    Not sure if it is possible out of a car
    However I think it needs to go back in a canbus car - from there the coding can be set to Kline (it'll stop working in that car) and now it'll talk on Kline when put into your car
    I may be totally off the mark but had to do something similar with a BT module that came from a TT
  7. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Dec 2013
    Derby
    Ok thanks for your reply fella, probs end up leaving it as it is then. I can get the directions up in the dis but have to turn the stereo off & then back on before it displays. Can't access my phonebook through the stereo either
  8. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Dec 2013
    Derby
    Quote Originally Posted by Shakeeb_5 View Post
    How did you manage that fella?
  9. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Feb 2014
    West Sussex
    That does sound like it could be the problem then
    What BT module do you have as that will also determine phone book capability
  10. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Dec 2013
    Derby
    That I'm not sure of but it all works fine on the steering wheel but can't make a call from the stereo itself.
  1. Fault in Radio/Navigation after retrofit RNS-E
    By westiej in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-01-2015, 03:48 PM
  2. Question Audi Navigation System Plus RNS-E....Radio problems
    By martynash in forum In Car Entertainment
    Last Post: 02-07-2014, 12:45 PM
  3. RNS 315 sat nav/radio/cd player - possible bluetooth module?
    By Pysces in forum Touran - Sharan - Caravelle
    Last Post: 08-06-2013, 10:13 AM
  4. Need advice please: Engine Control Module can not communicate
    By chips in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2012, 09:53 PM
  5. RNS 510 Radio Navigation System
    By LuvWatch in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-11-2009, 08:55 PM
