Thread: RNS-E Vagcom won't communicate with radio or navigation module
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Apr 2014
    A, A
    Checked the kline wire was in the right place as per the stereo wiring diagram (on top of the stereo), i've got a diagrm to aid it. For me it was in the right place just the vagcom cable knackered as someone else has coded it for me using the genuine cable...don't know how to add a diagram to this post unfortunately...if you message me separately i can send you the diagram
  2. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Dec 2013
    Derby
    Mine has the diagram on top too fella, I used an adapter to wire it from the original wiring setup to rnse which claimed to be the correct adapter. Kind of used to it now but it does bug me.
  3. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Apr 2014
    A, A
    Quote Originally Posted by Audi A4 S line View Post
    Erm well on top of your old stereo should show where the k line wire is on the original connector, you then follow the wire trhrough the adaptor to the rns e and make sure its in slot b5
  4. Re: RNS-E Vagcom won't communicate with radio or navigation module
    Sep 2009
    batley
    Did you get this sorted
    Mine has been exact same, still cant connect to radio or nav
    Moved wire from pin c7 to pin b5
    Still cant connect
  1. Fault in Radio/Navigation after retrofit RNS-E
    By westiej in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-01-2015, 03:48 PM
  2. Question Audi Navigation System Plus RNS-E....Radio problems
    By martynash in forum In Car Entertainment
    Last Post: 02-07-2014, 12:45 PM
  3. RNS 315 sat nav/radio/cd player - possible bluetooth module?
    By Pysces in forum Touran - Sharan - Caravelle
    Last Post: 08-06-2013, 10:13 AM
  4. Need advice please: Engine Control Module can not communicate
    By chips in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2012, 09:53 PM
  5. RNS 510 Radio Navigation System
    By LuvWatch in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-11-2009, 08:55 PM
