Thread: Kufatec "Soundbooster Pro Active Sound" fitted and working
Results 1 to 10 of 16
  1. Kufatec "Soundbooster Pro Active Sound" fitted and working
    May 2015
    United Kingdom
    Arrived this morning and fitted it already, was a bit harder than I thought as I had to remove all the trim from the right hand side of the boot.
    Managed to get it in and the button located near the OBD port, so it's completely hidden and out of the way but easy to press when driving.
    The tick over noise is nice in all modes with 5 and 6 being very loud, much louder than I thought, however revving the engine while stationary produces a very artificial sound (which I know it is anyway) and I am just hoping it sounds better when driving it. Off on a 70 mile motorway drive later so we will see.
  2. Re: Kufatec "Soundbooster Pro Active Sound" fitted and working
    Mar 2015
    Lanarkshire Scotland
    how you getting on with the Kufatec? Are you happy with it? Have you had any issues with it, eg error codes, undue attention from the police etc etc?
  3. Re: Kufatec "Soundbooster Pro Active Sound" fitted and working
    May 2015
    United Kingdom
    I like it, the sound it makes certainly turns heads. There have been no issues at all, no error codes or anything.
    There are 6 noise settings, 1 - 3 are a little bit quiet, 4 is the best for every day driving, 5 is LOUD and if you're driving around town it's the best one for turning heads, makes a proper v8 rumble. Setting 6 is a little artificial and supposed to sound like an R8, it's a bit too high pitched for me.
    Recommended - yes!
    Audi A6 BiTDi Black Edition (C7)
    Gone:- C63 Coupe (2014), Audi S4 (B8), BMW M3 (E90), Audi RS4 (B7), BMW M5 (E60), BMW M3 (E46)
  4. Re: Kufatec "Soundbooster Pro Active Sound" fitted and working
    Mar 2015
    Thanks for the feedback. Did you have problems routing the switch through to the front of the car?
  5. Re: Kufatec "Soundbooster Pro Active Sound" fitted and working
    May 2015
    United Kingdom
    No really, the switch is attached and wrapped in standard automotive insulating tape, I tucked it under all the trim along the drivers side of the car and then drilled a small (6mm I think) hole near the OBD port to attach. The hardest part is removing the boot liner but I could have done that easier by opening the hatch I think.
    30 minute job maximum and very little knowledge required.
  6. Re: Kufatec "Soundbooster Pro Active Sound" fitted and working
    Feb 2014
    norway
    will this work on A7 TFSI?
  7. Re: Kufatec "Soundbooster Pro Active Sound" fitted and working
    May 2015
    United Kingdom
    No, only the Bi-Turbo Audi's with the active sound exhaust
  8. Re: Kufatec "Soundbooster Pro Active Sound" fitted and working
    Feb 2013
    Gloucester
    57 Post(s)
    Quote Originally Posted by soft View Post
    Unfortunately not, sounds amazing in the A7 BiTDI though
  9. Re: Kufatec "Soundbooster Pro Active Sound" fitted and working
    Mar 2015
    forgot to ask - can you switch it off or do you have to have at least one of the settings running? Not sure if my wife will like it!
  10. Re: Kufatec "Soundbooster Pro Active Sound" fitted and working
    May 2015
    United Kingdom
    Yes, with the sound in the MMI set to Dynamic that means it's on, then you have 7 settings, 1 being off, 2-7 being different types of sound.
    Also if you set the MMI to anything other than Dynamic it's completely off.
  1. A4 B6 ALT 2.0 "PRND" light with CVT Rattling Sound
    By cmulindwa in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-11-2014, 02:34 PM
  2. A6 Drivers Door Fault "Production Mode Active" ?
    By Jaset in forum VCDS - Help Requests
    Last Post: 19-01-2013, 09:06 AM
  3. Please Help "Airbag/B Pretensioner not active"
    By ladycool in forum Golf MK4 - 1999 - 2004
    Last Post: 01-08-2010, 01:43 AM
  4. Please Help "Sound surge / thump"(?) when using USB / Ipod A4 Bose
    By fattiereturns in forum In Car Entertainment
    Last Post: 23-09-2009, 05:32 PM
  5. Clutch Pedal making "Clicking" sound when pressed down
    By Eire12 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-05-2009, 04:26 PM
