Thread: Sat nav RNS 510 updates.
  1. Sat nav RNS 510 updates.
    vespa Guest
    Hello guys,
    I am considering updating my VW RNS 510 sat nav. I have seen discs advertised for 25 ish that are supposed to be genuine VW parts. If VW update it with a genuine disc, what is the cost? I am not that au fait with sat nav discs, so what are your recommendations, real VW by VW, done by VW or a disc advertised as gen VW? Also how do I find out what version I have now?
  2. Re: Sat nav RNS 510 updates.
    SE London
    There may be later information available than this. But to tell what will install on your RNS510 would have to know its model # revision
    3C0 035 684A -- Initial RNS-510 release unit. Latest firmware available is 1040, only via update. Compatible with 32GB SDHC cards after 1040 firmware upgrade only.
    3C0 035 684B -- Second release unit. Latest firmware available is 1040, only via update. Compatible with 32GB SDHC cards after 1040 firmware upgrade only,
    3C0 035 684C -- Third release unit, phased out for version E. Latest firmware available is 1040. Compatible with 32GB SDHC cards and now with LED backlit screen.
    3C0 035 684D -- Third release unit, phased out for version E. Latest firmware available is 1140. Compatible with 32GB SDHC cards and now with LED backlit screen. Only D version units should have firmware 1140 installed.
    From 12MY new units are:
    3C0 035 684E/F and 3C8 035 684E/F -- end of 2011/early 2012 RNS-510 release unit. Latest firmware is 4366 which brings version to J. Voice Command enabled. Faster onboard processor. Super-quick and fresh GUI, Sirius (north American subscription satellite radio) Travel Link. New firmware. f40GB Hard Drive. HD Radio Text support. This is the biggest improvement on top of version C unit. Compatible with up to 2TB SDXC cards.
    3C0 035 684G/H -- 2012 summer release RNS-510, phased out for version J/K. Same set of features, with some bug fixes and future firmware upgrades. All Version G units are manufactured starting end of June 2012. Firmware update on G/H to 4366 brings it to a J model.
    3C0 035 684J/K -- latest 2013 release RNS-510, phased out for version L. SSD hard drive standard, factory firmware is 4369 with plenty of performance improvements due to implementation of solid state hard drive. All version K units are manufactured starting end of June 2013. Firmware can be upgraded to 5374.
    3C0 035 684L -- Latest 2014 release RNS-510. SSD hard drive standard, factory firmware is 5378 with plenty of performance improvements due to implementation of solid-state hard drive. All version L units are manufactured starting end of November 2013. Version L is the fastest functioning RNS-510 manufactured to date. All version L units come with freshly minted 2014 maps database.
  3. Re: Sat nav RNS 510 updates.
    vespa Guest
    Thank you for your reply. Sadly I am a bit miffed with these new gadgets in cars and still use the map books and forward planning. Where can I find the model number of the RNS 510? It is a Sept 09 2.0 Ltr TDi Highline. Any ideas of the cost of an update?
  4. Re: Sat nav RNS 510 updates.
    vespa Guest
    I have had a VW quote of 125, so I will get a new paper map book unless anyone knows any cheaper options.
  5. Re: Sat nav RNS 510 updates.
    SE London
    For maps, my last JVC update (the KW NX7000/EE was introduced into UK market in 2008, I bought in '10) was €109.90 (plus bank's "foreign transaction" rip-off fee) branded TeleAtlas but sold by TomTom in 2013. Previous to that all map updates were annual and free. My last firmware update was free in '11. Yes, I could've bought a book. When was that book last updated? Sorry, missed the point.
    To show the current firmware and map versions on an RNS510 press and hold in the Setup button for 10 secs. If this doesn't give you the screen then it may have to be activated in VCDS
    Hope that helps
  6. Re: Sat nav RNS 510 updates.
    vespa Guest
    Thanks for that info RichardSEL
  7. Re: Sat nav RNS 510 updates.
    Oct 2020
    Cleveland, Ohio
    Quote Originally Posted by RichardSEL View Post
    Would you happen to know a link to where I can find
    HW: H23 / SW: 5374 (3C0 035 684L) US VERSION firmware?
    SWL ERROR RNS510 VW 2014 Passat SEL TDI - Album on Imgur
    My system keeps rebooting the Fender Screen, spent all my dough on the car and just won another ticket for using my phone while driving
    I tried one update though won an SWL update
    Thank You ,
    Rosie
  8. Re: Sat nav RNS 510 updates.
    Sheffield, UK
    Mine doesn't match any of those, I had the unit out recently to install a DAB Pure kit.
    The part number on top is 1T0 035 680 C, I haven't updated it for a few years and the maps are out of date so could do with a refresh.
    VW Passat Sport Estate 170 TDI
    Sheffield, UK
  9. Re: Sat nav RNS 510 updates.
    Sheffield, UK
    Quote Originally Posted by Rpetrovski View Post
    Thank You ,
    Rosie
    I found some info here.
    I've managed to install 3810 on my unit (1T0 035 680 C). Seems to start up a lot faster, left the car 3 days so no battery drain (I've never suffered with that though, mine is a Sept 2007 model so it might not affect me anyway).
    I've obtained the latest maps as well but not sure if they'll install on my unit as it's pretty old and I can't remember the HDD size.
    Sheffield, UK
  1. Volkswagen RNS-510 Sat Nav fitting
    By ryang148 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-04-2013, 10:22 PM
  2. Please Help RNS 510 sat nav paking sensors park assist
    By Rob_Infiniti in forum Touran - Sharan - Caravelle
    Last Post: 11-05-2012, 02:24 PM
  3. Ebay alternative to VW RNS 510 Sat Nav
    By rjordan2008 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-07-2008, 10:18 PM
  4. RNS-510 TouchScreen Sat Nav
    By eko in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-04-2008, 10:20 PM
  5. Touchscreen RNS 510 Sat Nav
    By Trikster in forum Golf MK5 - 2004 - 2009
    Last Post: 18-01-2008, 05:19 PM
