Thread: Audi A6 3.0tdi air bubles in fuel line
  1. Audi A6 3.0tdi air bubles in fuel line
    May 2015
    Sofia, BG
    hello, i have a problem with 2006 audi a6 3.0 tdi. Recently i had injectors refurbished. The car was running fine but there was smoke from the exhaust. We changed the injectors and the smoke is gone but exactly after that a problem with air in the fuel occurred. If you push the car on 3-4gear above 3000rpm the car gets unresponsive and there is lack of power, when i pop the hood there are bubbles in the fuel pipe. When driving the car in the city there are no problems at all, this occurs only above 80kmh and above 3000rpm. The fuel filter was changed 4000km ago with audi oem filter. I had doubts about the fuel return lines from the injectors.I guess the o-rings that are on the injectors are not high quality, but they are not leaking fuel. Is it possible that they leak air in the system on high load? Should i try another filter and change the black valve above the filter. The pipes in the engine compartment seems well and not leaking. In it possible that the filter in the tank got clogged and the pump is not generating enough pressure? An suggestions are welcome
    P.S. The car starts fine, no matter how long it stood...
  2. Re: Audi A6 3.0tdi air bubles in fuel line
    Nov 2012
    Somerset UK
    A VCDS scan looks a good place to start.
  3. Re: Audi A6 3.0tdi air bubles in fuel line
    Pembrokeshire
    22 Post(s)
    air bubbles mean that air is being sucked in somewhere. possibly from a connection on a filter, maybe further back. you need to find it and cure it and then it should be alright.
  4. Re: Audi A6 3.0tdi air bubles in fuel line
    May 2015
    Sofia, BG
    There are no trouble codes at all. I`ve changed the o-rings on the return line and no change. Tomorrow i`ll change the fuel filter again and i`ll order the preheater valve and i`ll hope that this will fix it
  1. Air Leak in Diesel fuel line after Fuel Filter Replacement
    By CliffA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-05-2015, 09:55 AM
  2. Please Help Fuel Economy Plummeted A6 Avant 2.0TDi S-line 2008
    By NealLynch in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-01-2015, 02:04 PM
  3. Please Help air in the clear fuel line
    By audia4lyn in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-09-2009, 11:14 PM
  4. air bubbles in fuel line
    By Red Ed in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 26-05-2009, 02:34 AM
  5. Air in fuel line
    By decka in forum Touran - Sharan - Caravelle
    Last Post: 30-04-2009, 10:22 PM
