Thread: Gearbox Problem - Unable to select 5th & 6th gear
  1. Gearbox Problem - Unable to select 5th & 6th gear
    Jun 2011
    Warwickshire
    I've been having a problem with my gearbox for a few weeks now. When driving I'd find it hard to select 5th and 6th and then the next day it would be fine again.
    It's now got that bad that I can no longer select them. It's like there is something blocking them.
    Reverse and gears 1 - 4 are perfect, no issues. There is no crunching or grinding sounds when changing gears and no problems with the clutch.
    I took it to my local Audi specialist, He had a look at the linkage and selectors and said the fault seems to be internal and would mean removing and stripping the gearbox which would take a few days and cost quite a bit. Estimated around £1000
    Has anyone come across this before? or any ideas what it might be?
    Seems like a very expensive repair and I'd like to rule out smaller things before dropping that kind of money.
  2. Re: Gearbox Problem - Unable to select 5th & 6th gear
    May 2016
    Oxfordshire
    I have had the same problem, did you find your gear stick became loose when in 6th gear also? Mine only gets bad when I have done a few miles on the motorway and have stayed in 6th gear for a few miles.
  3. Re: Gearbox Problem - Unable to select 5th & 6th gear
    Jun 2011
    Warwickshire
    I didn't find it becoming loose really because it was a nightmare trying to actually select 6th gear.
    I replaced the gearbox in the end, I picked up a second hand gearbox and had it fitted locally. Still cost around £600/£700 but it's been running smoothly since.
    Best of luck getting it fixed!
  4. Re: Gearbox Problem - Unable to select 5th & 6th gear
    May 2016
    Oxfordshire
    Cheers, how mang miles do you have on the clock before you had to change? Mines done 92k, cheers.
  5. Re: Gearbox Problem - Unable to select 5th & 6th gear
    Jun 2011
    Warwickshire
    I think I had around 120k.
  6. Re: Gearbox Problem - Unable to select 5th & 6th gear
    May 2016
    Oxfordshire
    Ok, cheers for your help.
  1. Help A3 Unable to select Reverse Gear
    By avitmark in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-11-2011, 12:10 AM
  2. Please Help Mk3 Tdi can't select 3rd,4th or 5th gear!
    By djl78 in forum Golf MK3 - 1993 - 1999
    Last Post: 24-09-2010, 09:33 PM
  3. Question unable to select reverse gear
    By stan still in forum Polo - Derby - Lupo - Fox
    Last Post: 30-01-2010, 11:15 PM
  4. Hard to select Reverse & 5th gear
    By the_old_diver in forum Touran - Sharan - Caravelle
    Last Post: 06-12-2009, 10:54 PM
  5. Please Help Funny noise from manual gear box on 5th & less on 6th
    By nazjazz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-12-2008, 09:04 PM
