Thread: Best cold weld/ sealing solution
  1. Best cold weld/ sealing solution
    Dec 2014
    Kent
    Hi All
    I need to seal a small split in the erg cooler pipe and was wondering what the best solution will be
    I have used glue / gels/ pastes / gun gum that 'set like steel ' but they just seem to blow off off with the high pressure
    Other than welding - has anyone got any advise what to use ? - the split is right on the join so its hard to apply a wrap around tape style solution
  2. Re: Best cold weld/ sealing solution
    Aug 2011
    Meath
  3. Re: Best cold weld/ sealing solution
    Dec 2014
    Kent
    many thanks
  1. Can anyone weld stainless on here and have some ramps?
    By mne666 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-10-2012, 08:32 PM
  2. Question Sealing polen filter housing
    By soulstyler in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-07-2012, 10:09 PM
  3. VW Golf TDI MK3 clutch pedal weld broke
    By typolee in forum Golf MK3 - 1993 - 1999
    Last Post: 09-07-2009, 10:09 AM
  4. Door sela not sealing
    By jackg in forum Early Passat Forum - Pre 97
    Last Post: 16-11-2008, 07:41 PM
