Thread: Piano black scratch removal?!
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Piano black scratch removal?!
    May 2008
    Southampton
    Hi all, just as the title suggests, my piano black trim has got swirls and fine scratches all over it. This is on the dash as well as around the gear selector. Has anyone else found this and is there a way to remove them? Any suggestions greatly appreciated.
    FYI all I ever clean the trim with is a micro-fibre cloth.
    Cheers, Matt
  2. Re: Piano black scratch removal?!
    Dec 2010
    CD UK
    6 Post(s)
    No experience, but something like (jeweller's) glass polish might work without being too abrasive. Try westfalia for options.
    Toothpaste might be too abrasive, but still an option as it has been recommended for windscreens by Honest John IIRC.
  3. Re: Piano black scratch removal?!
    Aug 2013
    18 Post(s)
    Pick an inconspicuous spot and give Brasso a try
  4. Re: Piano black scratch removal?!
    Feb 2009
    Glasgow UK
    How about ScratchX?
    might be worth a go, try a little area first and see how it goes
  5. Re: Piano black scratch removal?!
    May 2008
    Southampton
    Thanks for the suggestions chaps, I'll have a go and report back!
  6. Re: Piano black scratch removal?!
    Aug 2014
    Shrewsbury, Shropshire, England
    Hi Matt
    I use Poorboys Black Hole. Works a treat and its so cheap
    Andy
  7. Re: Piano black scratch removal?!
    Aberdeen
    63 Post(s)
    Do you know anyone who is into detailing? Get some help from them. It is possible to remove the trim and machine polish but you will probably get good results doing it by hand. Start with the finest polish and pad and work up. Meguirs 205 or Koch Chemie micro cut are well respected but there are lots out there.
    I would tread carefully with Brasso as I think it is hydrocarbon based which isn't great for plastics. May be wrong but you should manage to find the MSDS online.
    What kind of MF are you using to polish the trim? You need to use a deep pile one like car pro boa not a thin cheap one. Apparently the Korean ones are the best!
    Have a search on detailing world in the interior section for some tips. Good luck.
  8. Re: Piano black scratch removal?!
    Aug 2013
    18 Post(s)
    I have always had great results with Brasso… most recently on a piano black TV base. Transformed from a hazy mess to factory new condition. I’ve used it on loads of plastics from PVC window sills to clock faces. If you’re worried you can water it down a little and just make sure it doesn’t overheat.
    polish plastic with brasso - Google Search
  9. Re: Piano black scratch removal?!
    May 2008
    Southampton
    Quote Originally Posted by Scott K View Post
    Thanks for the reply Scott, I was hoping not to go down the trim removal route! I just use a regular MF cloth (not deep pile) with a bit of Autoglym plastic and rubber. Maybe that's how it's getting the scratches?
  10. Re: Piano black scratch removal?!
    Aug 2013
    18 Post(s)
    I hate to use any product on the interior. If it doesn’t clean properly with a damp cloth I use a little Windolene. Very gentle on any surface and the vinegar in it lifts anything oily. No marks on the piano black trim at the centre console one year in.
    BTW, you’re probably doing it already, but make sure you fold the mf cloth in on itself as the binding can sometimes be a little abrasive.
  1. Question Piano black sline grill
    By Big G star in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-05-2011, 06:33 PM
  2. Piano Black Dash?
    By PHPsauce in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-01-2011, 10:11 PM
  3. Piano Black Inserts
    By Scooby-Doo in forum Passat CC
    Last Post: 07-01-2011, 09:40 AM
  4. Piano Black inlays
    By mkc in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-06-2008, 05:10 PM
  5. Piano Black Interior Pack
    By SHAZA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-04-2008, 03:26 AM
