Thread: So I scanned a 210K 98 mk3 golf...
  1. So I scanned a 210K 98 mk3 golf...
    Feb 2014
    Leicestershire
    19 Post(s)
    My friends at work.
    It has more rot than fault codes... 1 code!
    Electrical intermittent when he unhooked te battery to weld up the exhaust
    Credit to the 1.9 PD engine
  2. Re: So I scanned a 210K 98 mk3 golf...
    May 2015
    durham
    I have just bought a A4 and it has the 1.9TDI PD engine with 104k on it and i was told this was a very good engine and it wont give me any trouble. Is this right because i have seen so many of the 2.0 TDI with oil pump failure.
  3. Re: So I scanned a 210K 98 mk3 golf...
    1840 Post(s)
    Alex, a 98 Golf 3 TDI would not have a PD engine, it is VEP.
    John, yes the 1.9 is fine and in fact oil pump failure on the 2 litre balancer shaft engine is not a big as a problem as internet scaremongers would have you believe.
    1 4 0
  4. Re: So I scanned a 210K 98 mk3 golf...
    May 2015
    durham
    Great thanks for that info. I was told its a common issue with oil pumps on the 2.0TDi and over the last 6 months i have seen 3 cars come in with the oil light on red and knocking bad. There is a VW specialist not far from where i work so i called them and they told me they see lots of these engines with pump failure so they now find it better to replace the engine and turbo rather that a rebuild because it costs much more. It could well be down to there being lots of these cars in my area as to why they see so many and i would probably guess that if the service history was up to date then there would be a lot less people suffering with this issue.
  5. Re: So I scanned a 210K 98 mk3 golf...
    Feb 2014
    Leicestershire
    19 Post(s)
    I stand corrected
    It was just an excuse to scan something else realy!
    0 3 0
  1. Replies: 0
    Last Post: 10-04-2012, 02:11 AM
  2. seat leon scanned and found
    By hongkongstuey in forum VCDS - Help Requests
    Last Post: 01-02-2011, 10:20 PM
  3. Would you buy an 01 A4 2.0TDi SE est 130hp with 210k
    By Cupat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-12-2010, 09:11 PM
  4. just scanned the passat?
    Last Post: 03-07-2009, 07:52 PM
  5. Question Golf Mk4 door handles on Mk3 Golf....
    By roosevelt1st in forum Golf MK3 - 1993 - 1999
    Last Post: 16-03-2009, 05:09 PM
