Thread: Blown Turbo or Stuck EGR Valve
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: Blown Turbo or Stuck EGR Valve
    May 2015
    United Kingdom
    Well after 2 more days in garage they seem at a loss. Not engine codes and therfore I am strongly thinking head gasket or head but as they saying it's intermittent (can run for hours with loads of white smoke and then hours with. Any ideas people? Thanks
  2. Re: Blown Turbo or Stuck EGR Valve
    Pembrokeshire
    22 Post(s)
    more likely to be an injector sticking open.
  3. Re: Blown Turbo or Stuck EGR Valve
    May 2015
    United Kingdom
    Thanks. Did I read somewhere about £1200 for a new injector? I'm loathed to pay after replacing the turbo for the same fault.
  4. Re: Blown Turbo or Stuck EGR Valve
    Pembrokeshire
    22 Post(s)
    send them to diesel bob or take them to a diesel place to have them tested.
  5. Re: Blown Turbo or Stuck EGR Valve
    May 2008
    40 Post(s)
    Get the injector trim codes read.
    Basically every injector runs within a set of parameters, and the ecu can correct the fuelling within these parameters, once they get to their limit of adjustment the ecu can go no further and you get running/smoke problems, any indy code reader should be able to do this, literally a few minutes work sitting in the drivers seat.
    Again if you do some research getting the common rail injectors tested is not as easy as people think, Ive read quite a few posts on different forums where people have done just that, got them back with a clean bill of health and problem still there, then spent **** loads more money fixing stuff that didnt need fixing only to replace the injector/s with new ones and faults go away!
    I would find a good specialist as they are bound to have seen this problem before.
    I have been saying for a few years now that as diesels get to clever the way to cheap motoring is naturally aspirated petrol engines.
    Euro6 diesels are way way more complicated
  6. Re: Blown Turbo or Stuck EGR Valve
    May 2015
    United Kingdom
    A big thank you. I am going to call the garage this afternoon as seems I will have to pull out of there. No idea what I do with the £1500 turbo that has been needlessly fitted.
  7. Re: Blown Turbo or Stuck EGR Valve
    #17
    Aug 2011
    Meath
    Small claims?
  8. Re: Blown Turbo or Stuck EGR Valve
    #18
    May 2008
    40 Post(s)
    Proving anything against the garage is going to be almost impossible.
  9. Re: Blown Turbo or Stuck EGR Valve
    #19
    May 2015
    United Kingdom
    Well over 3 weeks since I first took my car into the garage (and apart from having it back for 3 days) they still have it and admit they are at a loss. Getting p'd off now. Fault comes and goes (some is definately white and oil/diesel smell).
    I am reluctant to just drive the car away to another garage (and a new bill) when they have virtually agreed with me that the turbo was likely not the original culprit. They never return my calls and I had to turn up today unannounced and now they promising a head pressure test (but it's not losing water or oil in water/water in oil) so I am starting to believe from a 3rd party what I hear that it's overfuelling (stuck injector?). Garage say not possible as no fault codes BUT does this show up as a fault code?
    Worst case I ask them to put my old turbo back on, refund me £800 and then use this towards my next bill. As I have the old turbo is there anything I can look at? No play in the impeller as far as I can see and turns freely.
    Thanks people!
  1. whats the sign of turbo and EGR valve starting to fail
    By markoA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-01-2014, 12:06 AM
  2. EGR valve and Turbo
    By daled in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-01-2013, 02:56 PM
  3. 1.9TDI jerking/no turbo after replacing EGR valve
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 26-07-2011, 06:52 PM
  4. turbo not working..after replacing egr-valve
    By tonty42 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-03-2010, 11:25 AM
  5. Question EGR valve / Turbo problems
    By ian vincent in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-02-2010, 07:44 PM
