Thread: 2003 Audi 1.9 TDI AVF Engine Question
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
  1. 2003 Audi 1.9 TDI AVF Engine Question
    Apr 2015
    Damascus, Syria
    Hi All,
    was just looking at some other posts on the forum concerning newer A6's , especially from late 2004 ( facelifted model ) up to 2006. Seems that these diesel engines were prone to injector and timing chain issues, which seem to have been ironed out from 2006 onwards. Did the earlier1.9's ( especially mine !!! 2003 AVN 1.9 TDI ) have these problems?
    Thanks in advance.
  2. Re: 2003 Audi 1.9 TDI AVF Engine Question
    Mar 2013
    Virginia Co Cavan Ireland
    No buddy, no chain on the 1.9s, they were pretty much bulletproof as long as they get oil changes.
    Mick
    99 Bora Tdi
    1 1 0
  3. Re: 2003 Audi 1.9 TDI AVF Engine Question
    May 2012
    Everywhere
    308 Post(s)
    Injector loom usually breaks down after 200K .
    1 1 0
  4. Re: 2003 Audi 1.9 TDI AVF Engine Question
    Apr 2015
    Damascus, Syria
    Thanks Gazworld, assuming that the clock is telling the truth, @ 130'000 Mls, I have a fair bit to go yet. But for a part to hold for 200'000 Miles, is not so bad. Are they expensive to buy, and complicated to fit? or just straight forward remove / replace? or will need re/programming, which could be done with the VCDS unit recommended in this forum? Do you have the same car as me? 2003 Audi A6 S6 RS6 1.9 TDI ? What kind of problems have you had with it?
    Thanks for you help and advice...this will be my first A6 experience, and I plan it as a hobby car, but also as a comfortable workhouse.
    All the Best,
    Jim
  5. Re: 2003 Audi 1.9 TDI AVF Engine Question
    May 2012
    Everywhere
    308 Post(s)
    Hi Jimbo , got a 2003 AVF 1.9 tdi Passat, they are very closely related to a C5 A6 .
    Usual water ingress and a dead locked door .
    Bottom right of your build sticker do you have OGE or OGZ ?
    1 1 0
  6. Re: 2003 Audi 1.9 TDI AVF Engine Question
    Apr 2015
    Damascus, Syria
    Hi Gazwould, sorry for delayed reply...travelling a lot lately. Under the heading M-AUSSI./OPTIONS
    EOA OGE 4UF 6XD
    What does this mean? Thanks,
    Jim
  7. Re: 2003 Audi 1.9 TDI AVF Engine Question
    1840 Post(s)
    EOA , not listed so probably F0A (standard vehicles, not special version), no OGE code so probably 0GE (EU3 emissions standards), 4UF (drivers and passengers air bag with passengers override switch) and 6XD (electric and heated door mirrors) are known as PR codes and denotes features fitted to the car.
    1 1 0
  8. Re: 2003 Audi 1.9 TDI AVF Engine Question
    Apr 2015
    Damascus, Syria
    Thanks crasher. Underneath the EOA OGE 4UF 6KD Line are the following linrs:-
    1KD JOR 1LB 1BV
    3FA 5TM 7XO
    FOA 8GU OG1 OYC OJH
    T9J 3ND BJK U1D X2B 1N1
    2PV 3HA 8G1 9GO 8Z5 D3E
    7QO CL6 7KO 4X1 VJ1 6R2
    3PF 4KC 3YO 4K4 5D1
    1SA Q1D 4GP
    1539 7,9 4,9 6,0 161
    Thats everything on the sticker in the boot, ,,,,thanks for having a look, Jim
  9. Re: 2003 Audi 1.9 TDI AVF Engine Question
    1840 Post(s)
    1KD rear discs 245x10 Lucas TRW
    J0R 80aH/380A battery
    1LB front discs 288x25 ITT ATE
    1BV Sports suspension by Quattro GMBH
    3FA No sunroof
    5TM Glossy aluminium dash and door panel inlay trims
    7X0 No rear parking aid
    F0A Not listed
    8GU 140A alternator
    0G1 Manual with selector rods
    0YC Rear axle weight range 3
    0JH front axle weight range 8
    T9J 4 cyl TD AVF or AWX
    3ND Non folding rear seat backrest
    BJK Not listed
    U1D Not listed
    X2B Not listed
    1N1Not listed
    2PV Sports steering wheel for air bag
    3HA Door panel trim foil/cloth
    8G1 Not listed
    9G0 Not listed
    8Z5 Engine coolant system version 1
    D3E 4 cyl TD 96Kw
    7Q0 No navigation
    CL6 7.5Jx17H2 Et43 alloys wheels
    7K0 No tyre pressure control system
    4X1 front side air bags
    VJ1 Reinforced bumpers
    6R2 Not listed, possibly “no centre arm rest”
    3PF Electric height adjust front seats
    4KC Green tinted glass for doors, side and rear
    3Y0 Not listed but probably “no rear window blind”
    4K4 Not listed but probably “green tinted laminated windscreen”
    5D1 433.92Mhz remote control central locking
    1SA Not listed but probably “no engine protection grill”
    Q1D Sports seats front and rear
    4GP Windscreen with sight glass for VIN
    1 1 0
  10. Re: 2003 Audi 1.9 TDI AVF Engine Question
    May 2015
    Kirmington, North Lincolnshire
    170k AVF TDi, thermostat, coolant sensor, fuel temp loom issue and new EGR, Tunit V-PD fitted, turned right up, no issues at all.
    Bit of oil smoke on startup, clears quickly, could well be turbo seals.......
    Probably the most reliable part of the car
    1 1 0
  1. Please Help Audi A4 2003 1.9 tdi 130 bhp (engine code avf)
    By shabbs81 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-10-2014, 09:04 AM
  2. Question Passat TDI engine (AVF) injector rocker snapped
    By RedOne in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-07-2013, 10:13 PM
  3. Please Help 2002 Passat TDI 130 - N75 Valve / ECU Problem - AVF Engine code
    By mickeybo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-10-2011, 07:28 PM
  4. Attention Live data from tdi engine AVF 96 kw - Vag Com
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2011, 11:57 PM
  5. Question A4 TDI AVF orange engine warning light
    By adrianw in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-05-2008, 01:07 PM
