Thread: Smoke pouring out of all air vents when the temp dial is not on Max cold/blue
  1. Lightbulb Smoke pouring out of all air vents when the temp dial is not on Max cold/blue
    Apr 2015
    Bedford
    Whenever I turn the heat dial up from anything that isn't max cold/blue smoke pours from all open air vents and completely clouds up the windscreen. It smells like a fluid burning. After driving for a while and with all the air vents on full blast and max heat the smoke eventually stops and won't happen again, but then when I stop and turn of the ignition for more than 10 minutes it will start again pouring out smoke. I thought it would eventually stop but it's been going on for a month or so now.
    any ideas?
  2. Re: Smoke pouring out of all air vents when the temp dial is not on Max cold/blue
    Pembrokeshire
    22 Post(s)
    is it losing coolant. probably a leaking heater matrix.
  1. Question Blue smoke on cold start up?
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-01-2012, 11:09 PM
  2. Blue Smoke on Cold Start
    By tdci115 in forum Golf MK5 - 2004 - 2009
    Last Post: 30-07-2011, 07:18 PM
  3. smoke coming through air vents
    By DropKickMurphy in forum Golf MK3 - 1993 - 1999
    Last Post: 27-08-2009, 09:45 AM
  4. blue smoke from cold
    By jc_geddes in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2009, 09:38 PM
  5. smoke from air vents Audi Cabrio
    By chieflorenzo in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 18-03-2008, 02:24 PM
