Thread: Suspension question
Results 1 to 10 of 11
  1. Suspension question
    Feb 2012
    Wilton, Wiltshire, United Kingdom
    So from a distance today i noticed my car had a lean
    Got home from work and tested with a ruler
    Rear passanger side 1.5cm higher than the rear passanger
    Front passanger 1cm higher than the drivers passanger
    Fronts about 4cm higher than back
    I can here no knocking from any wheel
    The car a4 avant s line b7 currently has 19inch wheels on so not much clearance anyway
    I had planned putting a tow bar on this weekend but am now worried about the suspension
    My guess would be snapped springs but as i cant here any knocking cant see how this would be the case its a very firm ride as id expect from an s line although only had the car a week
  2. Re: Suspension question
    Pembrokeshire
    22 Post(s)
    a snapped spring won't cause a knocking under most circumstances. you need to get it in the air and examine them in turn. if its not obvious, check the ends, they should be a clean square end, look for a jagged end or rust. its not always easy to find them. also look for broken bits either top or bottom.
  3. Re: Suspension question
    Feb 2012
    Ok no idea why i seemed to think a snapped spring would cause a knock,
    I had put tomorrow morning asside to fit a tow bar so looks like ill be inspecting springs instead,
    is there anything else it could be ?
  4. Re: Suspension question
    Feb 2012
    Well rear spring snapped
    time to research this job
  5. Re: Suspension question
    Feb 2012
    Well off to audi tomorrow to order/get new springs
    been reading through haynes manual and it seems fairly simple, now this worries me slightly as i thought it would be more complicated
    all the online guides are for complete replacement and i only want to do rear springs
    my book basically just says compress springs, and remove
    is it really that simple ?
  6. Re: Suspension question
    Feb 2012
    Well quick update,
    ordered springs via audi £188.42 for the pair, i know i could have got a full set of lowering springs at that price but eould rather keep the s line springs for time being.
    Have a friend who can lend me spring compressor tonight so will hopefully be back in the avant in no time
    luckily for me i still have my saloon so so daily choors resume
  7. Re: Suspension question
    Feb 2014
    Leicestershire
    19 Post(s)
    Do use a proper spring compressor, seen a half baked job with G clamps go wrong, wasn't pretty.
  8. Re: Suspension question
    Feb 2012
    I learned ages ago to use correct tools, ive spent hours trying work arounds to end up buying the tool i was first advised to use now i either borrow or buy whats needed beforr i start
  9. Re: Suspension question
    Feb 2012
    Today was a fail,
    ill be trying again tomorrow
    found that the threads of the compressors get in the way and i cant line the spring up properly
  10. Re: Suspension question
    Feb 2014
    Leicestershire
    19 Post(s)
    Bummer,
    It's good when you get it done yourself though
  1. suspension question
    By waynegts in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2014, 01:38 PM
  2. Suspension question
    By Tobez in forum Golf MK3 - 1993 - 1999
    Last Post: 04-01-2012, 11:20 PM
  3. S4 suspension question
    By monkshood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-10-2010, 10:43 AM
  4. suspension question..
    By probert993 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-02-2010, 10:04 PM
  5. Suspension question...
    By MR.FUSION in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 07-09-2008, 10:34 PM
