Thread: RNS510 upgrade
Results 1 to 10 of 12
  1. RNS510 upgrade
    May 2014
    Manchester
    Has anyone upgraded their passat to an RNS510 and what coding did you have to do, if any
  2. Re: RNS510 upgrade
    SE London
    Quote Originally Posted by BobbyBrown View Post
    It's Plug 'n Play if you have a Passat with a later level of CANbus module -- later than revision "E". What year have you got? You can see what CANbus you have in VCDS. Or by reading its numbers on the module itself which is located (on RHD cars) behind the climate control panel. Take care if removing that panel if you have Climatic system as that has a bowden cable attached to it which is difficult to re-locate into correct position again when replacing.
  3. Re: RNS510 upgrade
    May 2014
    Manchester
    It does work and sounds good but I've added an external amplifier so I need to recode the system so that the RNS510 doesn't pre-amplify the signal. I also had to recode to get the nav instructions on the MFD
  4. Re: RNS510 upgrade
    SE London
    AFAIK you can't use a low-level external amp with VW-OEM headunits. Only a high-level one that will accept low impedance (high level) inputs such as designed for speakers. Same problem for a sub -- there's no output for one unless you get one that accepts high level inputs
    This is in contrast to aftermarket headunits that do provide all the options -- this, the CANbus update, and other restrictions caused me to decide on a JVC DAB etc. back in 2009 that's still in use today
  5. Re: RNS510 upgrade
    May 2014
    Manchester
    I have an Audison 8.9 that takes its input from the speaker out of the RNS 510.
    Are you saying I don't need to recode the unit?? I was under the impression I had to use VCDS to drop 'output stage power 26 dB” to “output stage line-out 12 dB'
  6. Re: RNS510 upgrade
    SE London
    Further my last just had a look at the configuration codes for RNS510 and there are coding options for audio correction, for Dynaudio, and for Active Speakers. If you've already bought your amp and it's only got low-level input you could try the Active Speakers coding option. But I think the VW-supplied Dynaudio factory option took hi-level inputs. The Ross-Tech wiki doesn't say whether Active Speakers drops output to Line Level. But given that active speakers means with an amp, hopefully that'll do it for you
    VW Radio Navigation System (RNS510) - Ross-Tech Wiki
    If I find the Dynaudio conversion notes I had (have changed PCs) I'll look it up
    Last edited by RichardSEL; 21-04-2015 at 12:37 PM. Reason: correct RoW label file - Long Coding
  7. Re: RNS510 upgrade
    May 2014
    Manchester
    Thanks Richard, orders the VagCom stuff today so I can have a play tomorrow. I'll 'hopefully' provide a definitive answer on what coding results in the best sound (or muck up everything trying).
  8. Re: RNS510 upgrade
    May 2014
    Manchester
    Ok coding done and here's what I've found:
    Coding needs to be changed to VW sound system - this drops the internal amping of the signal (my amp has therefore compensated by decreasing Vrms on each input to 4.0V)
    No speaker monitoring
    Active speakers
    This sounds a lot better and there are a lot less problems with bass when you turn the unit up. Distortion is also non existent and you can use the full volume range so I'm happy with this and would definitely recommend it.
    If you're getting someone else to code your unit you can also remove the restriction that prohibits you from inputting an address above a certain speed.
  9. Re: RNS510 upgrade
    SE London
    Glad you got it working. Post a pic of your final install?
  10. RNS510 upgrade
    May 2014
    Manchester
    Not a lot to show really, it's pretty much a zero on the chav scale..
    ImageUploadedByTapatalk1430132460.485111.jpg head unit has been coded to give the Premium skin
    ImageUploadedByTapatalk1430132523.532741.jpg audison 8.9 under passenger seat, can only be seen if the seat is pushed right back.
    ImageUploadedByTapatalk1430132558.728748.jpgJL microsub secured to back seats via Velcro. I've used the JL audio app and this position gives the best dB rating
    The AP1D mono amp is behind the boot panel so you can't see it. Boot lid covered with dynamat, as are the front doors.
    This is the software running on a laptop which allows you to customize the whole system
  1. Question RCD210 to RNS510
    By Samsian Gas in forum In Car Entertainment
    Last Post: 15-08-2012, 07:43 PM
  2. Question Rns510...
    By sixgixx in forum In Car Entertainment
    Last Post: 28-03-2011, 12:00 PM
  3. rns510 into b5
    By turbo2turbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-08-2010, 07:30 PM
  4. RNS510 or aftermarket RNS510 which one is better?
    By j32maniac in forum In Car Entertainment
    Last Post: 21-11-2009, 04:25 AM
  5. RNS510 - worth it?
    By mjcon in forum Golf MK6 - 2009 - 2013
    Last Post: 28-10-2009, 09:53 AM
