Thread: Steering Rack Replacement 2.7tdi Manual 2wd A6 C6
Results 11 to 20 of 23
  1. Re: Steering Rack Replacement 2.7tdi Manual 2wd A6 C6
    #11
    Mar 2009
    Kidderminster, Worcestershire and Tewkesbury, Gloucestershire
    sorry I didn't get around to it. Humphrey999 have you changed it yet?
    2007 A6 2.7TDi Avant Manual S-Line
    2003 A4 B6 Avant 1.9 TDi Quattro Sport, Manual -Sold
    1999T A6 C5 Avant 2.5 Auto, 244k -Sold
    2005 STM Phoenix R1 powered, 1988 205 Gti 16v tarmac rally car . . and a few motorbikes
  2. Re: Steering Rack Replacement 2.7tdi Manual 2wd A6 C6
    #12
    Mar 2011
    Bledlow Ridge, Bucks, UK
    No not yet, I'm going to replace the inner joints first before I jump in and buy a new rack...
  3. Re: Steering Rack Replacement 2.7tdi Manual 2wd A6 C6
    #13
    Mar 2009
    sent you my number if you need any advice
    mine, the main shaft in the rack had the chrome worn away, due to ingress of water I suspect
    the inner joints were fine. I still have them sitting on my bench if you need a picture of them, or any other part of the rack
  4. Re: Steering Rack Replacement 2.7tdi Manual 2wd A6 C6
    #14
    Mar 2011
    Thanks Phil, really appreciate your support - to be honest I'm waiting for the weather to improve having done the steering rack on the wife's Discovery 3 only two weeks ago and not having suitable cover against the elements. I doubt it's going to get any better soon though
  5. Re: Steering Rack Replacement 2.7tdi Manual 2wd A6 C6
    #15
    Mar 2009
    what's the issue with yours? are you getting play in the rack? Mine was a tiny bit of play, almost like too much back lash in the gears but I've since stripped the rack and it was ok. All I can think was barely perceptible play at the bearings at the outer ends of the rack casing, where the seals had perished due to hard chrome corroding away and damaging the seals
    I've had this issue [worn bush] on the 205 rally car, it makes for loose steering and along with a fierce LSD makes it a right fight to drive hard! the diff pulls the car all over the road!
  6. Re: Steering Rack Replacement 2.7tdi Manual 2wd A6 C6
    #16
    Mar 2011
    Hi, sorry for the delay in replying, I've been flat out at work (literally, around Rockingham!)
    On fidgety roads i get a knocking from the left front suspension direction. All the suspension arms bushings, TREs and ARB bushes are new, the ONLY bits that are original are the inner steering joints and the rack, the knocking can't be coming from anywhere else. Nothing through the wheel though...
  7. Re: Steering Rack Replacement 2.7tdi Manual 2wd A6 C6
    #17
    Mar 2009
    i think if the rack itself was shot like mine then it would be losing fluid, gaiters were full of fluid, only one side leaking out tho
  8. Re: Steering Rack Replacement 2.7tdi Manual 2wd A6 C6
    #18
    Mar 2011
    Well I would have agreed before I did the Disco one - that rack was loose as hell, and knocking through the steering but there was no loss of fluid. Shame the Audi rack seems so inaccessible in comparison...
  9. Re: Steering Rack Replacement 2.7tdi Manual 2wd A6 C6
    #19
    Dec 2007
    8 Post(s)
    Could it be loose mounting bolts on the rack.
    Some take a short cut by not replacing one of the bolts which is in a difficult position,but this would only apply if the rack was already replaced.
  10. Re: Steering Rack Replacement 2.7tdi Manual 2wd A6 C6
    #20
    Jul 2013
    76 Post(s)
    did you do the rack adjustment procedure to rule this out?
    Dan
    2009/2010 2.0 TDIe SE
  1. Replacement Steering Rack has changed steering
    By xandertarr in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-04-2017, 10:46 AM
  2. Please Help A3 steering rack replacement
    By Marcopolo1 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-01-2014, 10:58 PM
  3. Replacement Steering Rack
    By hidnmine in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-05-2012, 01:12 PM
  4. Steering Rack replacement
    By Wirral Allroad in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-03-2010, 05:43 PM
  5. Steering Rack Replacement
    By BIGECK in forum Golf MK4 - 1999 - 2004
    Last Post: 08-02-2010, 11:10 AM
