Thread: scirocco intermittent indicator fault
  1. scirocco intermittent indicator fault
    Apr 2015
    kilmarnock
    Hi, I own a 2008 Scirocco 140GT TDI DSG, when I indicate to the right, then put indicator stalk in the neutral position, the indicators start indicating to the left, and sometimes when switching to the off position they keep flashing to the right for a few seconds, I have tried this a few times but it seems to be an intermittent fault, but seems to do it more just after the car has been started. Cheers
  2. Re: scirocco intermittent indicator fault
    May 2007
    17 Post(s)
    Isn't that the "comfort indicator" function were the indicators flash 3 or 4 times after the stalk is returned to the neutral position? I think you can switch the function of in the MFD menu.
    If not then I think you'd need to have the switch output checked with a diagnostic tool to see if the signals the switch is sending to the control unit are correct.
    Jim.
  3. Re: scirocco intermittent indicator fault
    Apr 2015
    kilmarnock
    Quote Originally Posted by Flash2 View Post
    Jim.
    ok thanks for that I'll get get it checked out
  4. Re: scirocco intermittent indicator fault
    Apr 2015
    kilmarnock
    Quote Originally Posted by jodie1 View Post
    New indicator stalk fitted, problem solved!! cheers
  5. Re: scirocco intermittent indicator fault
    May 2007
    17 Post(s)
    Thanks for posting back to let us know the outcome. Glad you got it sorted.
    Jim.
  1. Question 2001 S3 Intermittent Indicator Issue
    By simonpieman in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-03-2014, 09:25 AM
  2. Question Intermittent fault
    By rswa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-02-2014, 05:54 PM
  3. Intermittent Fault
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-12-2013, 11:35 AM
  4. Intermittent Indicator "Out" fault
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-03-2012, 12:32 PM
  5. intermittent indicator noise
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-09-2009, 07:46 PM
