Thread: A3 gaiter removal
  1. A3 gaiter removal
    I need to lift the gear stick gaiter on my 2011 A3 to grease up a couple of squeaks - however I'm not 100% sure how to remove the gaiter. I don't want to start putting a screwdriver under the edges to try and prise it off or just pull at it for fear of breaking it, but no doubt there's an easy way to do it. I don't need to completely remove it as such either, just need access to below. Can anyone help? Thanks!
  2. Re: A3 gaiter removal
    Oct 2010
    rainham kent
    the surrounding trim comes off around it and then I'm sure you'll be able to work it out
  3. Re: A3 gaiter removal
    46 Post(s)
    no screwdrivers needed, surrounding trim comes off as jay says then the gaitor itself is held onto the trim with push-clips.
  1. B6 Gear Gaiter Trim Removal ??? (will not budge at all)
    By Warrenmole in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-06-2011, 07:54 PM
  2. Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    By frost015 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-03-2009, 09:08 PM
  3. Gear Stick Gaiter Removal
    By peplow85 in forum Altea
    Last Post: 08-09-2008, 07:45 AM
  4. CV Gaiter
    By Michelin in forum Golf MK4 - 1999 - 2004
    Last Post: 27-05-2008, 08:20 PM
  5. Gear gaiter removal
    By pa ousman in forum New Member Introductions
    Last Post: 08-12-2007, 04:48 AM
