Thread: Strange blowing noise...
  1. Strange blowing noise...
    Oct 2011
    Edinburgh
    Hi all,
    I've not been on here much at all recently (in fact, I can't even remember the last time I was!) as my 2006 A4 S-Line Tdi (140) has behaved impeccably for 3 year's now without a single problem.
    For the past couple of weeks now however, I've noticed that it has developed a really strange noise and I'm hoping that someone else on here might have experienced this. In 4th, 5th and 6th gear (and occasionally even in 3rd), at around 1500rpm i can hear what i can only describe as a 'blowing' noise, which sounds like it's coming from the air vents. I've also noticed that the engine seems to sound 'louder' in the cabin, especially when it's cold. I've also felt a little hesitation in 1st gear and I don't know if I'm imagining it or not, but it feels like it could be slightly down on power.
    I found this link: http://www.tyresmoke.net/forum/topic...e-above-60mph/ , which seems to point to a build-up of leaves and gunk in the drains. I got my mechanic to look at it and sure enough the drains were blocked and have now been emptied and cleaned, but the 'blowing' noise still persists. I told him yesterday that the noise is still happening and he's filled me full of dread by saying that it could be the start of the dreaded balancer shaft failure and has booked it in again for next week, but something is making me think that it could be more like a leak in a boost hose or perhaps even an air-con issue... Any suggestions?
  2. Re: Strange blowing noise...
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    By your description, I would hazard a guess at a Turbo boost hose split, or a loose hose clip....or, a leaking Intercooler. Sometimes not easy to spot.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Strange blowing noise...
    Jan 2015
    Keep revs above 1500 rpm anyway, engine and turbo will be happier that way.....
    don't doodle a tdi too much.
  4. Re: Strange blowing noise...
    Nov 2014
    london
    Quote Originally Posted by clockwork.satan View Post
    Hi all,
    If it almost sounds like the car is breathing through the vents on the left hand side check the connections to the turbo. I had this issue after an accident so returned my car to the insurers & the mechanic revealed the pipework going onto the turbo was not on properly.
  5. Re: Strange blowing noise...
    May 2008
    40 Post(s)
    I would agree turbo hose split, basically the engine starts to work properly at 1500 rpm upwards as the turbo spools into life and pressurises the intercooler pipework, its a common fault on all turbo vehicles, normally easy to spot by the tell tale signs of oil spatter.
  6. Re: Strange blowing noise...
    Oct 2011
    Edinburgh
    Oh, I should've come on here to say - the noise wasn't a blowing sound at all, my mechanic traced it to a rattling heat shield that was only rattling when the engine was within a certain rev range. So glad it wasn't anything serious!
    Thanks for the help though, guys.
  7. Re: Strange blowing noise...
    May 2008
    40 Post(s)
    Time for a hearing test
  8. Re: Strange blowing noise...
    Oct 2011
    Edinburgh
    Quote Originally Posted by lynalldiscovery View Post
    Haha! I was totally convinced it was a blowing noise. Oddly enough, there was a severe lack of power which was reset by him doing a reset via VAGcom to the ECU. Or something. I thought the noise and power issues were linked, but they weren't at all.
  1. strange noise
    By coup80 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-02-2013, 12:00 AM
  2. Please Help New To Forum: Blowing noise from engine. Is it safe to drive?
    By dph040778 in forum Bora - 1998 - 2005
    Last Post: 18-09-2012, 07:46 PM
  3. Please Help Exhaust blowing noise coming when starting in the morning?
    By vasi1982 in forum Golf MK3 - 1993 - 1999
    Last Post: 26-01-2010, 09:29 PM
  4. Question GT TDI Turbo noise blowing intercooler pipe off
    By tom1987 in forum Golf MK5 - 2004 - 2009
    Last Post: 27-12-2008, 10:35 AM
  5. help blowing noise fom engine ???turbo
    By kevb159 in forum Bora - 1998 - 2005
    Last Post: 26-10-2008, 10:39 AM
