Thread: Map and maf sensors
  1. Map and maf sensors
    Sep 2008
    mk4 golf 1.6 105ps 16v 2001
    does this engine have MAF AND OR MAP sensors
    its a bit of a puzzlement as my garage has billed me for fitting them
    hope someone can help please
    cheers
    geof
  2. Re: Map and maf sensors
    Sep 2008
    Quote Originally Posted by mrcrow View Post
    cheers
    geof
    anyone there?
  3. Re: Map and maf sensors
    Sep 2009
    London/Bucks England
    I would suspect MAP. Theres no loom after the throttlebody, and it looks like the map will be on the black plastic intake near the TB.
    If you had to disconnect any wiring from the air hose then it has a MAF.
    They are quite different, one is a small plastic pressure sensor which measures relative pressure - the other is a hot wire mesh which calculates oxygen mass from a temperature change which is considerably bigger.
    The best bet would be to pull the engine code from the chassis, unless its a donor - but in any case there should be a stamp on the block somewhere with a 3 letter code. If not the stickers are in the usual places on the car - door pillar, boot, bonnet. Or if you can translate your Chassis codes on the V5 you will also see the engine code in there.
    151 PS @ 3800 rpm 1.6 8V MPi - 31.5mpg urban <-- Happy days
    123k On the clock and counting. (25k on the block)
    I need all your V-Powers.
  4. Re: Map and maf sensors
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Map sensor at the end of the manifold where the dipstick tube heads down, no maf on that engine as far as I'm aware, if memory of my 1.4 16v serves me right.
    1 1 0
  5. Re: Map and maf sensors
    May 2007
    17 Post(s)
    Engine codes AEH, AKL & APF all have MAF sensors (no MAP).
    Engine codes ATN, AUS & AZD all have MAP sensors (no MAF), but if your engine isn't one of those, post your engine code and I'm sure someone will be able to tell you for sure what your engine has.
    The engine code should be on the white label on the timing cover.
    Jim.
  6. Re: Map and maf sensors
    Sep 2008
    very comprehensive and just the right info to find the car and engine details
    i did think it might have been the little sensor near the TB but being so new to this side of the engine functions needed to get some help
    thanks very much
    cheers
    geof
  1. Please Help 17964 fault? MAP valve (N75) & MAP sensor location ??? how to check vac lines?
    By spadders in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-03-2015, 09:55 PM
  2. Some MAP/MAF Analysis please
    By tjg04 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-02-2011, 07:28 PM
  3. Maf actual 430...maf specified 250?! any ideas?
    By ALIN in forum Golf MK4 - 1999 - 2004
    Last Post: 16-06-2010, 10:44 PM
  4. Where are these sensors? O2 - Lambda / MAF / ABS wheel speed rear left
    By p33tew in forum Polo - Derby - Lupo - Fox
    Last Post: 13-11-2008, 12:41 PM
  5. Turbo cutting out at around 60mph, have already checked MAf and Map Sensors
    By Don_passat98 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-05-2008, 10:28 AM
