Thread: Drivers side electrical problems Golf GT 2.0 FSI
Results 1 to 10 of 10
  1. Drivers side electrical problems Golf GT 2.0 FSI
    Apr 2015
    Berkshire
    Hi. This is my first post on a forum so go easy on me.
    I've got a 2004 Mk5 Golf GT 2.0 FSI. Not had it very long but running into problems already, all electrical and mostly drivers side (all except nav) but I'm sure they're connected. Right, here goes! Drivers mirror/switch - I press up on the switch, it goes right, I press down, it goes left, I press left, it goes up and so on. Power fold mirrors - I turn the dial to fold the mirrors in, left one works fine, drivers mirror folds out the wrong way. Drivers window works but one touch up and down will not work (have tried resetting the limits), passenger windows both work fine on one touch, drivers rear will only auto one way. Stereo/nav (mfd2) - will not turn on with ignition, have to do it manually every time I turn the car on, turns off before I take the key out of the ignition, won't remember where I was on cd but remembers radio stations settings etc. Sometimes get a bulb failure light on dash but goes once I cycle through from auto to dipped and back again.
    Had it on vag com today (wouldn't print results though which is really annoying) but all the mechanic said was it was showing faults in all items I mentioned.
    Not sure if it could be a problem with a module?
    Pulling my hair out here so any help would be great!
    Cheers.
    2004 VW golf GT 2.0 FSI
  2. Re: Drivers side electrical problems Golf GT 2.0 FSI
    May 2007
    17 Post(s)
    If you can get vag com back on it, check the coding of the door control units just in case somebody has been messing with it.
    Here is sample coding from another 2004 Golf (3 door model) that might help confirm if yours is correct :
    Driver-side door electronics - MIDI
    Part No : 1K0 959 701E
    Coding 52
    Passenger-side door electronics - MIDI
    Part No : 1K0 959 702E
    Coding 52
    1 1 0
  3. Re: Drivers side electrical problems Golf GT 2.0 FSI
    Apr 2015
    Berkshire
    Quote Originally Posted by Flash2 View Post
    Coding 52
    Coding 52
    Ok, thanks. Will get it back on this week. Mine is a 5 door, does that matter?
  4. Re: Drivers side electrical problems Golf GT 2.0 FSI
    May 2007
    17 Post(s)
    Coding on a 5 door models will probably be different but I'd guess both the N/S & O/S doors should have the same coding number. So check the coding of your passenger door and see if that matches the drivers.
    If not, take a note of the original coding number of your driver's door, then change the coding to the same number as the passenger door and see if that changes anything. If it doesn't fix it, just re-enter the original coding.
    Jim.
  5. Re: Drivers side electrical problems Golf GT 2.0 FSI
    May 2007
    17 Post(s)
    Update : Just checked a 4 door model and it also has a coding of 52 on each door too. Yours may have a different number because yours is a higher spec model. You could enter 52 in both your doors (if they're different) and see if that changes the way the mirror is working. Just be sure to keep a note of the original coding numbers before making changes so you change it back if you need to.
    Jim.
  6. Re: Drivers side electrical problems Golf GT 2.0 FSI
    Apr 2015
    Berkshire
    Jim.
    Hi Jim. I've had a look at the coding today. The passenger door is on 54 and the drivers door is on 677. I changed the drivers door to 54 as well but it just started controlling the passenger door so I changed it back.
    Anyway, did a full scan and here are the results :
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: Sporadic communication error 1000
    42-Door Elect, Driver -- Status: Sporadic communication error 1000
    56-Radio -- Status: Malfunction 1010
    76-Park Assist -- Status: OK 0000
    =20
    Address 01: Engine Labels: None
    Part No SW: 06F 906 056 DE HW: Hardware No=20
    Component: MED9.5.10 00 6304 =20
    Revision: 00000000 Serial number: VWZ7Z0D9943604
    Coding: 0000072
    Shop #: WSC 01392 785 00200
    VCID: 6FE7CD657E862D1
    Part No: 06F 907 807 D
    Component: NOX 0406290103 006 4109
    06F907807D NOX 0406290103 006 4109 =20
    1 Fault Found:
    16575 - Fuel Pressure Sensor (G247)=20
    P0191 - 008 - Implausible Signal - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103 =20
    Coding: 0021122
    VCID: 3A712C317544B89
    No fault code found.
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No: 1K0 907 044 AC
    Component: ClimatronicPQ35 066 0404 =20
    Shop #: WSC 00000 000 00000
    VCID: 68D5A6795B68FA9
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
    Component: Bordnetz-SG 1.0 H30 0704 =20
    Revision: 00030000 Serial number: 00000000859288
    Coding: E58D8F0600041800001400001400000000
    VCID: 40855ED91398E29
    Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer VW350 012 0401 =20
    Coding: 00065493
    Shop #: WSC 00000 =20
    Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
    Component: RegenLichtSens 005 0605 =20
    Coding: 00217125
    2 Faults Found:
    01520 - Rain and Light Recognition Sensor (G397)=20
    01331 - Door Control Module; Driver Side (J386)=20
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
    Component: 02 AIRBAG VW8 022 0600 =20
    Revision: 05022000 Serial number: 0033JD0FKRP$ =20
    Coding: 0012338
    Shop #: WSC 01371 785 00200
    VCID: 2D5B176DB40A1F1
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenks=E4ulenmodul 012 0030 =20
    Coding: 0000012
    VCID: 30650E19A338729
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 971 A
    Component: KOMBIINSTRUMENT VDD 0812 =20
    Coding: 0003403
    Shop #: WSC 00581 210 64475
    VCID: 2953E37D80E2031
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 C HW: 1K0 907 951=20
    Component: Gateway H08 0080 =20
    Revision: 08 Serial number: 260010462407BF
    Coding: 3D3F0748070003
    VCID: 2757E54596F6351
    4 Faults Found:
    01305 - Databus for Infotainment=20
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 1
    Fault Frequency: 254
    Reset counter: 7
    Mileage: 193683 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:49:36
    01300 - Control Module for Navigation with CD-Rom (J401)=20
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 7
    Mileage: 193683 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:49:37
    01304 - Radio=20
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 7
    Mileage: 193683 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:49:37
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 5
    Mileage: 193917 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 09:32:44
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 0812 =20
    Address 37: Navigation Labels: 1T0-919-887.lbl
    Part No: 1T0 919 887 C
    Component: Navigation 0413 =20
    Coding: 0000002
    VCID: 428154D11D94F09
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
    Part No: 1K0 959 701 L
    Component: Tuer-SG 024 2468 =20
    Coding: 0000677
    VCID: 377735054656A51
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.2 1301 =20
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No SW: 1K0 959 433 J HW: 1K0 959 433 J
    Component: 01 KSG PQ35 G2 031 0308 =20
    Revision: 00031000 Serial number: 00000000000000
    Coding: 81C802087F2D8505485FC69000
    Shop #: WSC 00357 210 63736
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719=20
    Component: Neigungssensor 003 0003
    Part No: 1K0 951 177=20
    Component: Innenraumueberw.004 0101
    1 Fault Found:
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
    Part No: 1K0 959 702 G
    Component: Tuersteuergeraet 09 0148 =20
    Coding: 0000054
    VCID: 336F0115522E491
    Address 56: Radio Labels: 1T0-035-095.lbl
    Part No: 1T0 035 095=20
    Component: Radio 0413 =20
    Coding: 0001402
    VCID: EBDF5975CA9E511
    1 Fault Found:
    00857 - CD Changer Unit (R41)=20
    003 - Mechanical Failure
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
    Part No: 1K0 959 703 C
    Component: Tuersteuergeraet 06 0202 =20
    Coding: 0000016
    Address 72: Door, Rear Right
    Cannot be reached
    Address 76: Park Assist Labels: 1K0-919-283.lbl
    Part No: 1K0 919 283 A
    Component: 01 Einparkhilfe 0101 =20
    Is it me or is everything pointing to the drivers door control module?
    Cheers,
    Dave
  7. Re: Drivers side electrical problems Golf GT 2.0 FSI
    May 2007
    17 Post(s)
    Well, it looks like the driver door control module has maybe already been replaced. The part number suffix is L on the driver door and G on the passenger door. On the diag logs I have, the two doors have the same suffix. That's not to say that in itself is the problem but maybe someone has replaced the module to try and fix this fault before.
    I also notice that VCDS can't communicate with the right rear door. The front & rear door modules are linked. Communication with the rear doors is via the front door modules. The communication faults could be due to wiring damage in the loom between the car body and the door. It might be worth popping off the rubber tubing where the wiring routes into the door and see if there is any damage. Here is a link that might be worth a read :
    Door wiring harness -cracked wire replacement - mk5 VW | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
    Jim.
  8. Re: Drivers side electrical problems Golf GT 2.0 FSI
    Apr 2015
    Berkshire
    Jim.
    Jim.
    Forgot to add this:
    Wednesday,22,April,2015,17:17:18:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Address 42: Door Elect, Driver Labels: =
    Control Module Part Number: 1K0 959 701 L
    Component and/or Version: Tuer-SG 024 2468
    Software Coding: 0000677
    Work Shop Code: WSC 00000 000 00000
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)=20
    005 - No or Incorrect Basic Setting / Adaptation - =
    Intermittent
    Wednesday,22,April,2015,17:36:11:32264
    1 Fault Found:
    01552 - Motor for Central Locking; Drivers Door (V56); Lock=20
    012 - Electrical Fault in Circuit
    Interestingly, I just looked up the '00932' fault code and it says "incorrect window motor/door control module installed"
    So with that in mind and you noticing that the part number is different, I'm just wondering if someone has had a go at it before and installed the wrong part.
    Think I might call VW tomorrow to see if they'll give me the correct part number and/or coding in case that is wrong, before I start taking the door apart.
    Thanks for all your help, I'll update you with any progress.
    Dave.
  9. Re: Drivers side electrical problems Golf GT 2.0 FSI
    May 2007
    17 Post(s)
    In my experience, the 00932 code is normally logged because the window up/down limits haven't been set for the one touch operation, but you said you had already tried to set them in your original post.
    The parts guys at your local dealer should be able to tell you if the part number is correct for your chassis number, but they wont be able to advise you on the correct coding because that depends on the what vehicle the part is to be fitted to. I'd be surprised if a parts guy even knew what coding was. I'm pretty sure nobody in the parts at my local dealership would have a clue, and having seen some of the techs there, I'm not sure they would know either
  10. Re: Drivers side electrical problems Golf GT 2.0 FSI
    Apr 2015
    Berkshire
    Just a quick update. Dealer didn't want to pay to have the car repaired so he offered to give me my money back. Bit sad to let the car go - then I bought myself a GTI which made up for it!
    Thanks for your help, much appreciated!
  1. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  2. Question mk5 Golf wind noise - drivers side
    By petesaysblimey in forum Golf MK5 - 2004 - 2009
    Last Post: 03-09-2009, 09:26 AM
  3. Audi A3 electrical problems following side impact crash
    By emma1234 in forum Audi A3 - Archive Topics
    Last Post: 27-11-2008, 01:34 PM
  4. Question electrical problems on left hand side of Golf MK5 GTi
    By mqondo in forum Golf MK5 - 2004 - 2009
    Last Post: 14-10-2008, 09:45 AM
  5. a4 p/side door electrical problems
    By stubbsy in forum Audi A4 - Archive Topics
    Last Post: 25-02-2007, 02:04 AM
