Thread: Water leakage
  1. Water leakage
    Sep 2007
    Hi, I have a 53 A3 2.0 FSI. Have had problems with coolant warning light and overrunning fans and have had both fans and switch replace. However now leaking water badly. Been in garage who have checked all the obvious things like water getting into engine/exhaust and they have run it on test for a day but couldn't find a leak. It's going back in on Thursday this week so would be grateful to hear if anyone else had had a similar problem and have managed to get it fixed.
  2. Re: Water leakage
    mcr
    Hi I Have The Same Problem As I Had My Radiotors Replaced As 1 Was Damaged. I Didnt Have A Water Leak Before But Now Have And Its Getting Worst Over Time Please Let Me Know If You Find Out Whats The Case. Regards Perci
  3. Re: Water leakage
    There is a common coolant leak on 2.0ltr fsi A3, coolant flange on side of cylinder head cracks or the o-ring leaks. Its on the right handside of the engine as you face it, difficult to see but if the leak is bad enough coolant runs down the block and can be seen underneath. Between certain chassis range the dealers was replacing the o-rings. Hope this helps
  1. Water
    By Shin in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-07-2007, 08:42 PM
  2. New leakage problem into passenger footwell
    By NickHuge in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-06-2007, 10:03 AM
  3. Audi 100 2litre 4cyl Coolant Leakage
    By dan~ in forum 100 - 200 - Turbo - 100 S4
    Last Post: 05-02-2007, 06:12 PM
  4. Water in car
    By scottishcruiser in forum Passat - Archive Topics
    Last Post: 15-01-2007, 08:09 PM
  5. Golf MK4 won't start - water leakage!!!! Any thoughts?
    By Wac1000 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-11-2006, 09:24 AM
