Thread: 2.5TDI AKE replacing the VP44 fuel pump
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: 2.5TDI AKE replacing the VP44 fuel pump
    Mar 2019
    Hi can you replace the 2.5tdi pump from top of engine? ie without removing front etc ?
  2. Re: 2.5TDI AKE replacing the VP44 fuel pump
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Quote Originally Posted by muso58 View Post
    I don't think so, as you need access to the belt, tensioner and timing bolts.
  3. Re: 2.5TDI AKE replacing the VP44 fuel pump
    Jul 2019
    The code (or pin) can be read from the old fuel pump. I changed the VP44 this year and I sent both the old and the new pump (also second hand) to a VP44 specialist, he checked the new fuel pump and decoded it using the data from the old fuel pump. The replacement pump cost me 300 euro. There are several types of VP44 pumps for the 2.5 TDi, the difference is in the letter next to the number 106. Mine was J.
    My VP44 died by my mistake. I shifted from 1st to 4th by mistake and the pump died. When I opened the hood, there was burning smell, the pump electronics was dead. The pump was probably gonna die soon, I just speeded things up. The same thing apparently can happen when you climb a tall sidewalk with no throttle pressed, so be careful.
  4. Re: 2.5TDI AKE replacing the VP44 fuel pump
    Jan 2019
    Suffolk
    9 Post(s)
    Quote Originally Posted by A6C5V6TDi View Post
    So are we saying here that if the engine is suddenly prevented from turning (stalled) this can damage the pump. If so, that seems like a bit of poor design. It's also, presumably, much more relevant to manual transmission. I have an allroad auto and, pretty much as you'd expect, it is content to bump up kerbs (assuming this is what you mean by climb the sidewalk) with the engine idling and if the kerb is too tall it will just wait, with the engine continuing to idle, until you press the accelerator.
  5. Re: 2.5TDI AKE replacing the VP44 fuel pump
    Jul 2019
    Quote Originally Posted by Amphitryon View Post
    Yes, it is poor design, or at least that's how the pump specialist explained it to me.
  1. Question 2001 Allroad 2.5TDI (AKE) Vaned pump bracket replacement.
    By 70chips in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-01-2015, 10:13 PM
  2. Dynamically Checking Fuel Pump Timing on 2002 Allroad 2.5TDi Automatic AKE
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-03-2014, 10:15 PM
  3. AKE Fuel Pump
    By Yorky Col in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-10-2012, 11:42 AM
  4. Some pics of my recent Thermostat and Water Pump change 2001 Allroad 2.5tdi AKE
    By skyegtb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-04-2012, 06:03 PM
  5. Dynamic Fuel pump timing V6 2.5tdi AKE
    By POLOACE in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-04-2008, 08:26 AM
