Thread: 2004 A3 2.0 FSI fuel pump keeps running
  1. 2004 A3 2.0 FSI fuel pump keeps running
    Apr 2015
    Hertfordshire
    Hello,
    The fuel pump is running constantly with the ignition off unless you pull fuse 27 (15 amp fuel pump).
    I have read the codes and am not sure wether i have 2 seperate faults?
    P0091 valve for metering short to ground lower limit reached intermittant.
    P2540 low pressure fuel sensor implausible signal Not a plausible signal.
    I started looking at the fuel pump problem and found a permanent live and earth outputting from the fuel control module with the ignition off.
    I removed the other wires to the fuel control module connector except for the main live and earth wires and the pump still runs with the ignition off.
    Does this look like a fuel control module fault and could the pump running constantly bring these codes up?
    Also the car wont rev past 3000 rpm then all of a sudden does which I'm presuming is down to the fuel pressure faults?
  2. Re: 2004 A3 2.0 FSI fuel pump keeps running
    Aug 2018
    Did you ever get a solution to this, was it the module?
  1. How To Disable fuel pump running when opening driver door on POLO 9N 2004 AZQ
    By romain27111 in forum VCDS - Help Requests
    Last Post: 07-09-2014, 02:42 PM
  2. 2.0t fsi fuel pump camm follower
    By sbt in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-02-2013, 11:26 PM
  3. A3 2.0L FSI 2004 fuel filter & tyres
    By dumpee in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-10-2009, 03:28 PM
  4. A3 fsi 2.0 fuel pump cost?
    By John Paterson in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-05-2009, 05:45 PM
  5. Fuel Pump Running???
    By sdk778 in forum 80 - 90
    Last Post: 31-03-2008, 02:37 PM
