Thread: Speed Sensor Range/Performance Code:16885
  1. Speed Sensor Range/Performance Code:16885
    Dec 2014
    United Kingdom
    Hi guys,
    I have this code that has brought my EM light on, along with two others. I am wondering if this would/could give a false speedometer reading by any chance?
    Gav
  2. Re: Speed Sensor Range/Performance Code:16885
    Southern County Softy
    20 Post(s)
    From the Ross Tech wiki
    16885/P0501/001281
    Contents*[hide]*
    1*16885/P0501/001281 - Vehicle Speed Sensor (G22): Implausible Signal1.1*Possible Causes1.2*Possible Solutions16885/P0501/001281 - Vehicle Speed Sensor (G22): Implausible SignalPossible CausesWiring/Connectors from/to Vehicle Speed Sensor (G22) faultyWiring/Connectors from Transmission Control Module (J217) to Engine Control Module faultyVehicle Speed Sensor (G22) faultyMalfunctioning Left Front wheel speed sensor (in vehicles that don't use a physical G22 sensor)Possible SolutionsCheck Wiring/Connectors from/to Vehicle Speed Sensor (G22)Check Wiring/Connectors from Transmission Control Module (J217) to Engine Control ModuleCheck Vehicle Speed Sensor (G22)Check ABS Brakes for faults and diagnose malfunctioning Left Front wheel speed sensor if applicable
    A4 2.5 tdi QS (mapped)
  3. Re: Speed Sensor Range/Performance Code:16885
    Dec 2014
    United Kingdom
    Quote Originally Posted by kite View Post
    16885/P0501/001281
    Contents*[hide]*
    Hi Kite,
    Thanks for your reply and input. I can't see on that response whether or not it could give a false speedometer reading?
  1. Cmp sensor engine speed sensor fault
    By rswa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-08-2022, 10:44 PM
  2. Replies: 0
    Last Post: 09-01-2014, 11:17 AM
  3. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  4. 16885 Vehicle Speed Sensor - drivin me crazy!
    By v12bug in forum VCDS - Help Requests
    Last Post: 01-07-2010, 07:18 AM
  5. Fault code 0203 (Hall effect sensor out of range)
    By Cawte12345 in forum Touran - Sharan - Caravelle
    Last Post: 08-12-2009, 01:37 AM
