Thread: Blower stone cold
  1. Blower stone cold
    Scottish Borders
    The heater blower suddenly started blowing cold on all settings, manual blower, temp gauge normal, checked under the bonnet, expansion tank had filled up so left it to go cold, removed expansion tank lid, and the water was still at the top, started the engine and air bubbles started coming out but level stayed at the top,
    Mechanic reckons heater flaps stopping water circulating could this be the cause???
  2. Re: Blower stone cold
    Scottish Borders
    Mechanic changed heater flap motor , still didn't circulate, I had a recon engine fitted 7 K ago, and the metal water pump from the old engine was fitted as it had only done 20K, he is going to check it and the thermostat anything else he can check???? superb 1.9tdi
    Getting desperate to get working and back to work
  3. Re: Blower stone cold
    Pembrokeshire
    22 Post(s)
    heater flaps stopping water circulation, seriously ? he needs to go back to school. its a constant flow heater, the flap directs the air and is nothing to do with the water flow. what you have is a fault thats indicative of a failed water pump. possibly a thermostat problem but unlikely. could also be a major failing of the new engine.
  1. Replies: 3
    Last Post: 03-11-2016, 02:20 PM
  2. No heat - cold air from blower
    By Mick Bright in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-10-2010, 08:58 PM
  3. vw lt28 no blower on cold mornings
    By paul-coyle in forum The Commercial Range
    Last Post: 20-01-2010, 11:16 AM
  4. Please Help I'm Cold! Blower working but no heat??!
    By cutler400 in forum Golf MK3 - 1993 - 1999
    Last Post: 05-01-2009, 01:48 PM
  5. Stone cold bottom rad hose...
    By colifeashots in forum Passat - Archive Topics
    Last Post: 24-02-2007, 04:16 PM
